RT6 Firmware RNEG2.1.G.5
Moderator: GiveMeABreak
- DamirMitrovic
- My Cars: Peugeot 508
I have a 2011 years Peugeot 508, I need Firmware RNEG2.1.G.5
CD NUBMER 7165
RNEG2.1.G.5
Thanks all this is urgent for me
CD NUBMER 7165
RNEG2.1.G.5
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: RT6 Firmware RNEG2.1.G.5
Sorry but V2.10 is unlikely to be available as it was only a factory-installed version and as far as I can see, never a public release.
You will only get the latest version 2.86 from the dealer now too. You should be able to go to V2.20 or V2.21 without the loss of data or a visit to the dealer, but any later version will need dealer intervention to prevent resetting to factory defaults.
- DamirMitrovic
Thanks for fast answer The actual consumption indicator only works after 30km/h. The front side sensors not work to 50cm (I have 4 sensors and 2 side points on the front)
Are there any config file?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
The front side sensors are for the parking space measurement system, so aren't used for the parking, so they should be measuring much larger distances. But the side measuring sensors only work at speeds under 20 km/h and only when the gap measurement button is switched on (illuminated).
As for the current fuel consumption, again, this function is only displayed from 20 mph (30 km/h), so is normal.
- DamirMitrovic
Nice and quality answer. I love people who don't hate to tell me nicely what can be a problem. Thank you from my heart
- DamirMitrovic
However, I have to go to the master to return everything as the factory set up. Only now do I see problems with lowering the window over the remote
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
That will be a BSI configuration issue, nothing to do with the RT6 unit as the RT6 doesn't deal with anything to do with the remote control fob or the locking.
- DamirMitrovic
That's right, I just don't know how that BSI went wrong.GiveMeABreak wrote: ↑08 Apr 2022, 09:42 That will be a BSI configuration issue, nothing to do with the RT6 unit as the RT6 doesn't deal with anything to do with the remote control fob or the locking.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Very likely it has been changed with Diagbox at some point.
- DamirMitrovic
They ask me for 80 euros, to return all to fabrice
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes, that's about right for a diagnostic charge - they will hook the diagnostic up to PSA servers and check it manually afterwards.
- DamirMitrovic
Thank you for the quick answers.GiveMeABreak wrote: ↑08 Apr 2022, 15:12 Yes, that's about right for a diagnostic charge - they will hook the diagnostic up to PSA servers and check it manually afterwards.
