Peugeot 308 2014 Check engine mystery
Martinz
Unread post by Martinz »
Hello everyone, I have quite the mystery with my 2014 Peugeot 308 1.6 THP (156hp gasoline). Im a second owner, I’ve bought the car from the local Peugeot dealer, as a buyback car. Unfortunately I inherited a really bad problem. The first year the car was burning quite a lot of oil, but I thought nothing if it because I read on multiple forums, that this engine is known to eat a lot of oil. We’ll long story short I got a “STOP Engine” light and when I went to the mechanic, they found out that the cylinder walls were scratched (interesting enough, the scratches were horizontal), hence that was the cause with the oil burning problem.
I payed, a little below half of the car price, for repairs which included:
Every engine gasket, oil filter, pistons, water pump, tensioner, drive chain, cylinder block (yes a whole block :)), spark plugs. (And I’m listing only the major parts of course)
After this major repair the car ran perfectly fine, for a year. I regularly checked all liquids, we did oil changes on 1000km, 5000km, 10000km (because its almost a new engine).
I thought that was it the car is now perfect but … check engine light. When you turn the car on it starts well and idles for lets say 30secs just fine, then cylinders 1,2,4 miss-fire and the car enters a “safe mode”, and starts working on 1 cylinder. That happens 90% of the time, if you somehow get past that point and the car warms up, the likelihood of miss-firing drops to maybe 5%.
So far, I’ve realigned the drive chain, because I’ve read that because it’s a really small one (like on bikes) it trends to move itself by some millimetres which might throw away the timing. That didn’t work so I replaced it, again no success. Then I replaced the spark plugs and the coils … no luck there too. I’ve also tries reseting and reinstalling the software. The last thing that has been changed is the high pressure fuel pump, and yes, no luck again.
So if someone somehow has gone through the same hell as me, can you please please please help me. I promise to fly to your country and personally buy you a beer. :)
x 6955
Re: Peugeot 308 2014 Check engine mystery
Have it diagnosed with a decent code reader and pop the codes up here along with your VIN. That is a good starting point.
Martinz
GiveMeABreak wrote: 06 Apr 2022, 09:23 Have it diagnosed with a decent code reader and pop the codes up here along with your VIN. That is a good starting point.
Hello, sorry for the month long reply, but had some troubles getting a code reader.
So VIN: VF3**************[VIN obfuscated, can be read by forum staff]
And faults:
x 1438
Unread post by xantia_v6 »
Check the compression of the engine.
Would the cylinder scoring in the old block be consistent with the engine having had water in it? That could have led to bent conrods.
x 6955
Here are the fault code descriptors to help you
Note the reference to running the diagnostics if the engine ECU is dormant as noted in the table below for this fault code:
The P0562 fault will occur if the battery is weak which will also affect the power steering which is electrically operated.
Make sure you don't have a near empty fuel tank while conducting the diagnostics as your fault P0313 is saying there is a minimum fuel level in the tank.
Fault Code: P0562
Description of Fault: Battery voltage signal : Voltage too low. Detection of battery voltage too low, following the starting phase. Battery voltage between 2,54 and 10 V (For 2 seconds).
Note: for this fault to present itself, at least one of the following conditions must be fulfilled:
  • Detection of the fault 3 min after the end of starting in main triggering mode
  • Diagnostics performed permanently during the engine ECU dormant phase
Conditions for Fault to clear: Battery voltage between 10 and 16 V (For 2 seconds).
Downgrade Modes whilst Fault is active: Purge canister permanently.
Symptoms:
  • Starting impossible
  • Starting difficult
  • Engine hesitation
  • Engine overheating
Suspect Areas:
  • Battery
  • Electrical harnesses
Fault Code: P0313
Description of Fault: Low fuel level signal : Minimum level reached. Suspicion of lack of fuel in the tank. The following conditions have to be met:
- Engine management ECU in main triggering phase (After 1 seconds)
- The "fuel level" information received from the CAN is valid
- Fuel level low
Conditions for Fault to clear: 10 s after refilling the tank
Downgrade Modes whilst Fault is active: None
Symptoms: Information fault
Suspect Areas: Fuel level indicator
Fault Code: P1336
Description of Fault: Combustion misfiring (impact on catalytic converter) : Cylinder undetermined. Ignition misfiring (Possibility of damage to the catalytic converter). The following conditions have to be met:
- Engine speed above 500 rpm and below a threshold defined in the engine ECU
- Torque less than a threshold defined in the engine ECU
- The crankshaft and the camshaft are synchronised
Conditions for Fault to clear: Stop the engine and restart, in order to re-inject into the cylinders cut off following the detection of ignition misfirings
  • Deactivation of the richness regulation
  • Deactivation of the canister purge function
  • Cutting of cylinders if fault persistent
  • Deactivation of checking of the canister purge
Symptoms:
  • Unstable idling
  • Idle speed too high
  • Lack of power
  • Engine hesitation
  • Emissions outside the norms
  • Excessive fuel consumption
Suspect Areas:
  • Fuel level
  • Sparking plugs
  • Setting the timing
  • Engine ECU
Fault Code: P1340
Description of Fault: Combustion misfiring (impact on catalytic converter) : No. 4 cylinder. Cylinder 4 misfirings (Possibility of damage to the catalytic converter). The following conditions have to be met:
  • Deactivation of oxygen sensor regulation
  • Deactivation of richness regulation
Symptoms:
  • Unstable idling
  • Lack of power
  • Engine hesitation
Suspect Areas:
  • Sparking plugs
  • Ignition coil
  • Fuel injector
  • Engine ECU
  • Engine compressions
Fault Code: P1338
Symptoms:
  • Unstable idling
  • Lack of power
  • Engine hesitation
Suspect Areas:
  • Sparking plugs
  • Ignition coil
  • Fuel injector
  • Engine ECU
Fault Code: P0087
Description of Fault: Fuel circuit : The pressure measured in the injection rail is less than the setting. Pressure in the fuel high pressure common injection rail lower than the pressure setting for a certain time (Less than 25 bars). The following conditions have to be met
- High pressure regulation active
- The fuel flow is between 5 and 180 %
- No adaptation of the high pressure pump in progress
Conditions for Fault to clear: The following conditions have to be met:
- Each time that the difference between the actual pressure in the fuel high pressure common injection rail and the setting is less than 25 bars for more than 2 s, the counter is decremented. If the counter is lower than 2, the first part of the conditions for clearing is validated.
- Each time that the difference between the actual pressure in the fuel high pressure common injection rail and the setting is greater than 25 bars for more than 2 s, the counter is decremented. If the counter is lower than 3, the second part of the conditions for clearing is validated.
  • Deactivation of the bringing to temperature of the catalytic converter
  • Engine operating with fuel pressure of 5 bars
  • Limitation of the engine load
Symptoms:
  • Lack of power
  • Engine speed stuck
Suspect Areas:
  • High pressure fuel pump
  • Low pressure fuel circuit
