Unable to remove scuttle panel
- x 6950
Re: Unable to remove scuttle panel
No problem, just note as per the procedure, the wiper arms need removing first.
Nego2403
Yes of course. The last time I had them off but the clips hold the scuttle panel on very tightly. I'll try with a plastic spudger prying away from the windshield next time.GiveMeABreak wrote: 01 Apr 2022, 12:19 No problem, just note as per the procedure, the wiper arms need removing first.
restlessderek
- New User
I have the same problem.
Unfortunately, I can’t access the link that you have posted, even after joining the forum. Can you help please?
- x 6950
You need to upgrade your membership to access the resources section where that link is stored.restlessderek wrote: 27 Oct 2024, 12:27 I have the same problem.
