Peugeot 3008 2010 MyWay RNEG issues
Moderator: GiveMeABreak
- My Cars: 2010 Peugeot 3008 1.6hdi exclusive
Re: Peugeot 3008 2010 MyWay RNEG issues
Thanks for that Marc, can I use the same built in GPS Antenna and Fakra connector for the GPS input on the new after market unit (screw type!) by using Fakra Z Male to SMA Male, possible link thanks.
There won't be any issues with power to the antenna for both GPS and Radio (FM-AM) as I'm sure you are aware all newer cars have powered antenna's.
Really appreciated Marc, and thank you again
Mat
Mat
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
If all the aerials are working OK, there's little point in ripping everything out - just use converters for the connections, I'm sure you'll be fine.
Some of the antennae are powered internally from the head unit and others have an amplifier further down the vehicle nearer to the aerial, often mounted above inside the rear of the headlining or on one of the rear pillars.
I'm trying to attach an image of the rear of the new unit, don't know how Marc
Also do you happen to know where the built in Bluetooth hands free microphone might be located in the 2010 Peugeot 3008 1.6hdi Exclusive and where the mic lead ends up in the dash?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Make sure you are in 'Full Editor & Preview' mode when posting (press the Full Editor & Preview button) to allow more features.
- Hit the Attachments Option
- Then select 'Add Files'
- Browse to your pictures either on your phone or PC and multiple select the ones you want to upload.
- Wait for them to appear as uploaded on the Forum
- Once uploaded, you then put the cursor where you want the picture (add a new line first) and then press the 'Place Inline' option next to your uploaded picture.
Do you happen to know where the built in Bluetooth hands free microphone might be located in the 2010 Peugeot 3008 1.6hdi Exclusive and where the mic lead ends up in the dash?
I have sent the image.
Thanks Mat
Thanks Mat
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Congratulations on posting your image, however it is about as much use as a chocolate teapot! It's no bigger than a postage stamp, so I don't know where you got the picture from, but I suspect it is a thumbnail image so is no good magnified up, hence I can't see anything. Try getting a proper sized image and then saving that and then uploading it.
As for the microphone, this is where you are likely to run into problems.
PSA microphones are integrated into the centre roof console. However, the wiring from the microphone often ends up going into a ribbon connection and disappearing into the loom and is very hard to find the routing. Many people have given up and simply wired their own microphone into the head unit for this reason.
Thanks Marc! Sorry mate, First image upload hence the thumbnail shot . Hopefully Ibcan get it right next time. Cheers for all the info!
Hi Marc, need a littler help with radio issue, So having installed the unit, however in testing stage FM tuner working fine having no issues but AM tuner not tuning into anything whether manually or on auto search. Don't understand, maybe you can give some insight please.
Thank You
Thank You
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Hi
There's nothing I can help you with there as this is not a PSA unit and therefore I can't tell you what any of their connections are or what the wires they have shown in their unit are from or go to. There are no pinouts with descriptions of their wiring, so nothing I can do. I suggest you contact the sellers and ask them to provide you with a proper wiring diagram at the very least.
Thanks, if can possibly help with AM tuner issue.. Both FM and AM tuners work with Rneg myway unit but the AM tuner not locking to any stations on the after market unit. Could it be anything to do with power to the antenna!?? Thanks
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes it could. As I mentioned above somewhere in one of my posts, there is often an electronic unit near the rear of the vehicle hidden under the head lining that may be a powered amplifier.
You'll have to pop your VIN up and I'll take a look at your vehicle specs.
Ok Marc ill do that tomorrow. Many thanks
