Hello.
I want to clean the coolant system.
The total capacity is almost 10 litres.
What is the correct mix between Total brand concentrated coolant and demineralized water? 50% 50%?? 30% coolant 70% water?
Thanks.
ES9 - Correct coolant mix with water
- x 8056
Re: ES9 - Correct coolant mix with water
You should get the information you need by following this link:
https://total.lub-advisor.com/totalfr
Franchute13
Thanks for answering.
I used the site to search for the 407 v6 gas but it doesn't help.
The site doesn't explain, it just says LOOK AT THE MAINTENANCE BOOK.
- x 8056
Normally there is guidance on the coolant bottle according to what temperature you want to protect the engine down to. Most mixes end up being in the 40:60 to 60:40 range. That's all I can offer, someone else may have more advice for you. Good luck
- x 8056
I have found another site which has concentration information on page 2, have a look at:
https://total-cdn-lmdb.afineo.io/tds/TD ... 101_EN.pdf
- x 6954
Citroen / Peugeot use Freecor DSC Fluid in all vehicles. You can buy from the dealer in various container sizes and in either the concentrated or ready to use variants.Franchute13 wrote: 02 Mar 2022, 14:09 Hello.
Thanks.
Franchute13
Hello.GiveMeABreak wrote: 02 Mar 2022, 17:07Citroen / Peugeot use Freecor DSC Fluid in all vehicles. You can buy from the dealer in various container sizes and in either the concentrated or ready to use variants.Franchute13 wrote: 02 Mar 2022, 14:09 Hello.
Thanks.
Here, in Argentina, the original PSA refrigerant is from Total.
Franchute13
Thanks! I will use a mixture of 40% coolant and 60% water.mickthemaverick wrote: 02 Mar 2022, 16:18 I have found another site which has concentration information on page 2, have a look at:
- x 6954
Old stock I suspect. They haven't used that for years..... but as long as you have the equivalent for what you need.Franchute13 wrote: 02 Mar 2022, 21:49Hello.
