C4 Conked Out Faults Logged
Doo
(Donor 2022)
x 121
Re: C4 Conked Out Faults Logged
Unread post by Doo »
wheeler wrote: 01 Mar 2022, 14:50 Are you talking about the little chain between the 2 camshafts? Cant think ive ever used any special tools for changing them apart from the normal ones for initially setting the timing belt. There should be marks on the sprockets & they line up with different coloured links on the chain.
Excellent, thanks. It's just that I saw fancy looking tools when I was looking for the chain on the bay. I ended up buying from a local trusted parts shop.
Has anyone seen the plot? :?
x 1435
Changing the chain = need to remove the cam carrier = need to remove the injectors. This can be, er, trying on this engine!!!
Doo
(Donor 2022)
x 121
RichardW wrote: 01 Mar 2022, 16:25 Changing the chain = need to remove the cam carrier = need to remove the injectors. This can be, er, trying on this engine!!!
Looking forward to it already :hb:
