C4 B7 lubrication fault code
torneol
- x 3
Hmmm, I got this type of information:
Lubrication system, pressure not consistent with atmospheric pressure.
Meaning what? Oil and filter has changed few thousand ago, Mobil 5w-30 ESP.
1,6 VTI 2011. Timingchaing, pistonrings aso. changed about 12000 km ago.
- x 6956
Re: C4 B7 lubrication fault code
Please provide the actual fault code if you have it and your VIN so we can relate the fault to the correct EMS.
torneol
- x 3
I dont have actual code, iCarsoft gives only that text.
- x 6956
I can't help you without a proper PSA code. Most diagnostic tools provide the code as well as the description, but not all the codes are PSA codes. But without any code I can't help you as there are lots of pressure sensors in the vehicle for different functions.
torneol
- x 3
Yeah, I understand this. I try to find out a proper faultcode.
I assume, that it might be intake manifold pressure sensor. At least I try to find and clean it.
Where is that sensor in 1,6 VTI engine?
- x 6956
But this could also be the oil pressure sensor, so we really need the code.
torneol
- x 3
Yeah, I've been in contanct to manufacturer of iCarsoft, so they try to figure it out, why my FR V2. 0 doesn't give any proper code.
Is there any smart way to measure those sensors?
torneol
- x 3
They answered to me, that they are still working with iCarsoft issue, but they have find out, that fault code is P15A7.
It seems to be oil pressure sensor?
torneol
- x 3
I have heard, that there has been some problems with oilpumps in VTI engines.
Is here any knowledge about that?
- x 6956
Can't help you without your VIN. I've asked for it previously and you haven't responded.
torneol
- x 3
Ouh, sorry about that! I forgat it, car was not at home then, but now it is.
torneol
- x 3
Does anyone have any experience about cleaning the oil pressure sensor? Or is it just easier to change it?
- x 6956
Ok, so this is the fault code descriptor:
So the first thing I would do is just change the Oil Pressure Sensor - I wouldn't bother attempting cleaning it, then see if that resolves the issue.
| Fault Code: | P15A7 |
| Description of Fault: | Lubrication system : Pressure not consistent with the atmospheric pressure. Comparison of the oil pressure measured and the atmospheric pressure. |
| Conditions for Fault to clear: | Confirmation of return to automatic mode on the piloted oil pump. |
| Downgrade Modes whilst Fault is active: | Change to "mechanical mode" on the piloted oil pump. |
| Symptoms: |
| Suspect Areas: |
torneol
- x 3
Ok, thank's for reply!
Do you or anyone else have knowledge about that sensor; is it quite common problem or quite rare?
- x 6956
The engine oil pressure switch on this model is attached to the oil filter housing.
