- x 6945
Re: Citroen and Peugeot Parts Requests
@Moizeaux
C4 Petrol
Pete, as per your post in your other thread:
Air Filter
OEM Part: 1444VW, £30.35
OEM Cheaper Alternative, Part: E147177, £8.45
Oil Filter
OEM Part: 1109AL (Purflux), £14.48
OEM Cheaper: E149134, £6.76
Fuel Filter (shown as not fitted for this vehicle)
Pollen Filter
OEM part: 647975, £42.65
OEM Cheaper Alternative, Part: E146177, £
OEM Premium Anti Allergen Filter, Part: 647941, £17.50
Timing Belt Kit
Belt, Water Pump, Timing Tensioner and Retractor Roller
OEM Original Kit Part: 1609525280, £192.07
OEM Cheaper Kit, Part: 1609120680, £135.48
Spark Plugs
OEM Original (Bosch) Part: 5960F3, £12.49
OEM Alternative, Part: 1625935580, £6.00
Coil Pack
OEM Part: 597098, £147.91
C4 Petrol
Air Filter
Oil Filter
Pollen Filter
Timing Belt Kit
Spark Plugs
Coil Pack
moizeau
- x 423
Thanks Marc.
Could you confirm the aux belt kit please?
1611279280
You've given me numbers for a coil pack. Is this a recommended service item?
Thanks again
1611279280
Thanks again
Pete
- x 6945
Here you go Pete, sorry I missed of the Alternator parts you wanted.
Alternator Tensioner Roller (6) Part: 1611425380, £122.22
OEM Drive Belt (20) Part: 5750 XG, £32.80
Alternative Approved Cheaper Belt, Part: 1612162780, £13.94
As for 1611279280 - No such part listed for this vehicle.
moizeau
- x 423
Thanks Marc, much appreciated
Pete
- x 8126
Marc, could you please confirm which type of eolys system, bag or tank, and fluid I need for my C4 Picasso on maintenance fleet. The VIN is VF7**************[VIN obfuscated, can be read by forum staff] which I believe you already have?
Cheers
Mick
Cheers
Mick
- x 6945
You have a tank reservoir variant, so no pouch Mick.
With a build date of 12495, that means you need Powerflex Additive.
Incidentally Mick - are you aware there is still a recall (aftermarket campaign) outstanding on this vehicle?
If not, give Citroen a ring and get it booked in. I can't tell you what it's for, but it will be F.O.C.
- x 8126
Thanks Marc, Yes you told me about the recall and it turns out to be something to do with the timing belt!! It is booked in with Robins & Day for this Thursday and I may well get them to do the EOLYS top up at the same time as I'm not really up to under car work yet!! Thanks again.GiveMeABreak wrote: 14 Feb 2022, 16:50 You have a tank reservoir variant, so no pouch Mick.
- x 6945
Ok, best of luck with it and to be honest they shouldn't charge much for this as it's a gravity feed fill and an engine ECU additive reset.
thesk3
Hi
I'm i need of some part numbers, and names for my Citroën C5 1.8i Petrol 2002 mk1.
underneath pics of the parts i need info on. i really hope you can help me with this
Thx in advance for any help and tip you can give me
1: Left is the height sensor for the rear suspension as you kan see the bracket that it's mounted on is fairly rusted and needs to be replaced. do you know the name and part number for that bracket? for a better view
look at pic 5 and 6.
middle ring is somekind of tri splitter for the hydraulic suspension system, do you know the actual name of it? then to the far right is there somekind of holder/bracket for the tube, do you know the name of that?
2: in the red circle is (i think it's called) the anchor plate is that correct? do you know the parts number for that? the thing in the middle green circle what's that?
3: in the middle red ring is the gas pressure thing, i can't recall the name, i think they're i bit easier to get? and in the top there's somekind og holder/bracket for the rear bridge, look at pic 4.
4: it's pretty rusted, maybe needs replacing, do you know the name for this thing?
5: all in these colored rings needs to be replaced, do you know what the correct designated names for them are? for a closer view look at pic 6.
6: 7: this thing is a bracket that holds the rubber thing that holds the exaust pipe.
8: this the connection between the exaust manifold and the flex tube that connect to the catalytic converter. how would you say the welding here? i didn't do it as i don't know how to weld. for a closer view look at pic 9.
9:
10: what is this thing?
9:
jac
- (Donor 2021)
Hello,
Please could you tell me if there is a unique part number for the wing mirror cap piece? (Plastic trim that clips over the eletronics etc of the wing mirror)
This is the sticker on the inside of it, near side. Thanks!
- x 6945
Please see the first post in this thread.thesk3 wrote: 16 Feb 2022, 10:55 Hi
- x 6945
Here you go:jac wrote: 16 Feb 2022, 14:46 Hello,
Item (2)
Left: 1609431380 £53.51
Right: 1609431480 £53.51
All prices inclusive of UK VAT @ 20% as of today, direct from Citroen.
Note: These are supplied unpainted, so if ordering them, make sure you use some latex gloves before handling to reduce oil / grease contamination prior to priming and painting.
quintet
- x 44
Hi Marc, when you get the time could you please obtain the part numbers for the following;
osr lucas brake caliper and the brake pipe thats directly connected to it, thank you.
Music keeps me going.
- x 6945
@Quintet:
No worries
Rear Right Caliper (TRW Lucas)
OEM New Original Caliper, Part: 4400N5, £259.28
Exchange Caliper Part: 1638156180, £138.38
Rear Caliper Pipe
OEM Pipe, Part: 4886Z7, £22.64
Cheaper Hose Option, Part: 1680022480, £26.06
(Note, the OEM hose is listed as slightly cheaper than the cheaper alternative!)
All priced as of today inc. VAT direct from Peugeot.
No worries
Rear Caliper Pipe
c.morewood
- x 55
Citroen C3 Symphony 2008 1.3Hdi
Hi looking for the gearbox bracket part no. and diagram. Its the one which carries the gear cables has 2 bolts and is located next to the starter motor ( starter motor in foreground in photo)
I've inherited this car and the bracket has broken and is held together by a cable tie. Also part no and diagram for the suspension top bearing as that appears to have seized as well.
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
