Uh oh it's taking an occasional new wobble!
Restarting there and the satnav was inoperable. Shows the following:
And no response from any button.
Sound from the aux input still there.
It seemed to reboot and the red led cam on fire a few seconds. It seems to be working fine again but I'm getting worried that the HDD is about to die. I looked at the threads outlining what you do to clone the drive contents and save them to another drive and fit a solid state drive in place of the hdd. Then reload the lot again.
Trouble is I am unsure what you need to install on your pc for this and the hardware.
Had anyone ever actually done this here?
RT4 Issues
aerodynamica
- x 215
RT4 Issues
Reason: Post moved to RT4 Telematics Forum
Graeme M
- x 6960
Re: RT4 Issues
One tip to save you some grief if you are going down this road - DO NOT fit a Solid State Drive. The RT4 unit you have pictured is designed to be compatible with the earlier PATA interface and therefore they do not support SATA speeds nor the additional SATA commands. A SATA drive may work for a while, but only at the slower ATA speeds, but more importantly, will soon start to grind to a halt as the drive fills up. The operating system used by the RT4 does not support SATA features like TRIM command and this affects how the memory cells on a SSD are handled for re-writes.
I recommend you use a Compact Flash Card (CF Card) which is PATA compatible and uses the same ATA command set if you are going to replace it. You will therefore need an IDE to CF card adapter inside the system.
I've only done this personally on my NG4 Navidrive and wrote a guide on it, but the RT4 is a lot smaller as my NG4 was a double DIN unit and had loads of room in there.
viewtopic.php?t=57430
aerodynamica
- x 215
Re: RT4 Issues
Thanks Marc, I'll admit I'm not particularly confident about this task.
Graeme M
