Engine turning over but refusing to start
Post Reply
KennyW
My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate
x 132
Post by KennyW »
Hi All,
Out of the blue the above happened.
Driven around locally all fine, stopped in local carpark, returned to car tired to start but nothing.
No fault code appeared when the ignition is turned on.
Where are the fuse/s relating to the injection system and appropriate relays ?
User manual no use.
Kenny
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5741
Re: Engine turning over but refusingto start
Post by GiveMeABreak »
Did you first try resynchronise the fob Kenny? This can happen when the rolling codes exceed a certain number (256 or something like that).
Remove key from ignition (important) and leave for 5 minutes or so, then insert the key, turn only to ignition, then within 10 seconds, press lock button for a couple of seconds, release and remove key - do not attempt to start yet. Exit vehicle, lock, unlock with the fob, then get in and try to start it.
My Cars:
x 732
Post by wheeler »
What car are we talking about here?
C15 Romahome White
CX 20 Polar White
x 5741
It's his X7 I'm assuming.
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
Yes X7. Will give the fob procedure a try
Still not starting after the procedure.
This has me puzzled.
My Cars:
x 732
Post by wheeler »
Plenty of fuel in it & is it the correct fuel? dont trust the gauge.
Have you tried giving the hand primer a few pumps then re try?
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
Wheeler,
Plenty of fuel in on Tuesday £50 worth. Tried primer pump and nothing but did remove fuel pipe from filter to engine no fuel.
So no fuel to engine, will check filter, also check for blockages , change filter.
Worth blowing through fuel line from tank.
Have to wait until weekend but weather to be horrible
Any further suggestions gratefully accepted
Kenny
aerodynamica
Donor 2023
Lexia Available: Yes
My Cars: 2008 C5 Exclusive Tourer
1993 Xantia 1.9 TD VSX Mk1 Sinker A.K.A Slugmobile 13'
'Old Katy'
previous convictions: totaling 52litres of LHM in one go:
1968 ID19B 'Old Polly' Stellar white
1993 Xantia 1.9 TD SX Mk1 Sinker Silver
1992 XM 2.0 SEi Turbo Manual Anthracite Grey
1982 CX 20 Pallas 'Old Goldy'
1993 XM 2.1 SD Auto Light blue
1993 Xantia 1.9 TD SX Mk1 Sinker light Blue
1982 BX 16 TRS 'Cyril' Vallelunga Red
1995 Xantia 1.9 D SX Auto Dark green
1977 CX 2400 Pallas C-Matic 'Aphrodite' Regatta Blue
1982 GSA Pallas SE Silver Pearl
1980 CX 2000 Reflex Vallelunga Red
1978 CX 2400 Pallas C-Matic 'Prometheus' Midnight blue
1984 BX 14E 'Cecil the slugmobile' Maroon
1987 Fiat Panda 'the mighty panda'
x 98
Post by aerodynamica »
O no Kenny, hope you get to the bottom of it.
Graeme M
My Cars:
x 732
Post by wheeler »
Might be worth trying a sniff of easy start to see if it will fire, might even be enough to get it home.
Did pumping the hand primer feel like it was getting harder or did it just feel empty?
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
Car at home, transported back. Primer but didn't go hard. But going to look at fuel filter and supply pipe from tank to filter for blockage. Nothing can be done until Saturday at the earliest but more like Sunday looking at the weather.
Kenny
aerodynamica
Donor 2023
'Old Katy'
x 98
Is there a way to test or check the fuel pump is pressurising the fuel rail?
Graeme M
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
I don't know but will wait on others with better knowledge to reply
My Cars:
x 732
Post by wheeler »
aerodynamica wrote: 07 Jan 2022, 22:08 Is there a way to test or check the fuel pump is pressurising the fuel rail?
By using live data on diagnostics
Do you have diagbox?
The next basic checks you want to do are check fault codes.
Check for cam & crank synchronisation.
Check the ECU can see a decent engine RPM.
Check the fuel rail pressure is at least 110 bar on cranking.
C15 Romahome White
CX 20 Polar White
x 5741
There are extensive fault codes for this engine - if you can get us the list of those that are appearing it will be a start Kenny.
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
Going to put the Diagbox on it tomorrow and see what codes there are.
Kenny
Post Reply
