Hi All French Car Fans
I purchased a 2007 Citroen Berlingo 5 Speed Manual.
It is stuck in a gear.
BUT, i can select all gears and hear it going into all gears,
If i put it in reverse or first gear and i try pushing it you can feel it is in gear.
In Neutral it is also in a gear but it is like a 5th gear ratio. Or 3rd.
I removed side cover and when selecting 5th gear the selector fork moves in and out.
Any ideas.
Thanks in Advance.
Citroen Berlingo Stuck In Gear, Selects all gears
Advanced Diagnostic
- x 1055
Re: Citroen Berlingo Stuck In Gear, Selects all gears
Assuming the selector cables are correctly fitted then im afraid its a gearbox strip down to see what’s gone wrong.
Advanced Diagnostic
Thanks for the quick response.
Do you have a link to diagrams on stripping down this gearbox.
I have tried to upload pictures but not yet getting hang of forum.
Advanced Diagnostic
Some pictures
- x 1490
There's a comprehensive guide here http://www.eastment.net/be3%20gearbox.htm the author is long time contributor here (although not currently active). This is an earlier box, but PSA haven't changed it much for nearly 40 years!
I would check the cables are properly seated and working however, before committing to stripping the box - these are very reliable and rarely give terminal trouble, unless run without oil.
Advanced Diagnostic
Thank You for the reply and link.
Yes we have checked the cables.
What i did now was to try all the gears with the clutch pressed and then moving the brake disk to see if the gearbox turns freely.
When in neutral clutch at released position, disk feel like in gear..
When in neutral clutch depressed then disk turns freely.
When clutch depressed and ALL gears selected, disk is still in gear.
Clutch released in ALL gears, disk still in gear.
4th And 3rd does not feel to go in all the way until i start wiggeling the disk front and back, but 4th is more of a problem getting in.
Hopes this makes sense.
- x 1055
By the looks of it there has already been a repair done to the gearbox, you can see the shaft nut has been re used (unless this was you).
Maybe a previous bad repair?
Advanced Diagnostic
No i purchased it not running so this is my first.
- x 1055
Someone has definitely been in there previously.
Advanced Diagnostic
I agree. As there was allot of sealant holding the 5th gear cover stuck.
I will remove the Gearbox today and then strip it down and i will keep all posted on progress.
Advanced Diagnostic
Hi All
Update on Gearbox This next Photo the synchro do not want to go to the bottom gear, which i think is 3rd. I cannot get them to line up to engage the gear. This bearing is plastic Any input is appreciated.
