Solenoid valve (turbo vaccum)
- New User
- My Cars: Citroen c4 1.6 hdi 2007 109ps
I had an error code p0234 on my citroen c4 1.6 hdi and i found that it was the solenoid valve which is located at the back of the engine.IF YOU HAVE ERROR CODE P0234 (OVERBOOST SITUATION) IT IS POSSIBLE THAT YOUR SOLENOID VALVE IS BROKEN.Here is a photograph of the solenoid valve
Re: Solenoid valve (turbo vaccum)
Thanks for sharing, my car is 2.0HDI, but I think your experience should also be suitable for my car, I have collected it.
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 825
The atmospheric port on the boost valve has a little foam filter, and if that is restricted, the valve can't dump vacuum fast enough, and that can trigger an overboost error.
- Donor 2023
- My Cars:
- x 4
Did it cause it to go into limp mode?
06 Citroen C5 Estate 2.2 Hdi Auto
95 Peugeot 306 S16
95 Silver Xantia VSX - now deceased
95 Peugeot 306 S16
