Citroen C5 can not connect to Bluetooth
- x 6947
Re: Citroen C5 can not connect to Bluetooth
You have the basic RD4 system on your C5.
Options are to upgrade to the later RD45 which incorporates Bluetooth within the head unit. You may need an updated screen and it will need VIN coding and configuring within the BSI.
There are other options for full telematics units (MyWay (RNEG), eMyWay (RT6), but these need apart from the Head unit and new large colour screen - a new fascia, wiring, GPS / GSM aerials, microphone connections and configuration.
Otherwise, leave the Head unit as it is and get an aftermarket unit for bluetooth / MP3 - something like one of the Yatour boxes that mimic a CD changer to play MP3s. They come in a variety of units that offer different functionality.
47vidm
Great thanks for replying, I will probably use the latter advice rather than changing the head and potentially the screen.
David
David
47vidm
Just a quick update I’ve decided to get an rd45 and a new screen from eBay it will come vin coded, is there a set procedure for replacement of the head unit and screen?
Also if anyone can offer any advice on how to get the screen out and the new one in.
Thanks in advance.
David
Thanks in advance.
David
- x 6947
Just make sure you have disconnected the battery following the BSI Reset / Battery Disconnect / Reconnect Procedure before dismantling and unplugging the unit as the connections are still live with the ignition off. Disconnecting the screen connections with power on can fry the unit.
Bear in mind though that although the supplier is VIN coding it for you, there are other configuration options for Country and various other setting that have options - so just to be aware.
As for removing the screen, you'll need to remove the lower dashboard trim strip that will show bolts to remove the panel that holds the air vents in (be careful removing this).
The RD4 radio unit is removed using these type of removal pins:
The unit will slide out and the connectors are accessible. Always disconnect the Quadlock connector (the large square connector) first and reconnect it last.
- x 1473
Be aware that the wiring to the microphone on the RD45 goes via pins that were not used on the RD4, so a new microphone cable, or some rewiring, is required for Bluetooth calls to work.
As Marc has said, don't be surprised if a diagnostics session is required to fix the configuration, I think that a parameter in the BSI may need adjusting to enable Bluetooth.
47vidm
Great thanks for the replies with great advice.
David
David
AceRider87
Hello there .
I’m new to citroen so please have patience .
So … the main issue is that i can’t connect to bluetooth . The ex owner had 3-4 phones connected so i think it worked . I have deleted all synct phones and NOTHING . I got the fuse out - NOTHING , done BSI reset - NOTHING .
I search for new device and i find CITROEN every time , i tried from phone and car and viceversa still NOTHING .it just wont connect .
Is there a possibility to update bluetooth firmware ?
My VIN nr is : VF7**************[VIN obfuscated, can be read by forum staff]
Please help cuz it’s getting frustrating .
Thank you very much
Thank you very much
- x 6947
I've checked and although you have an RD4 (not RD45) system there is a Nomad bluetooth unit installed - which should be providing the bluetooth connectivity.
So it is important that you fully remove the previous phones (make sure they are actually deleted from the system). You'll then need to add a new phone from the menu which should put it into search mode - which you'll need to check with the phone at the same time and pair it if it provides a code.
AceRider87
Did that a few times , didn’t work , still doesn’t connect . I also tried with 3-4 phones and also different codes (1111,0000,1234) still nothing .
I cant seem to find the difference between RD4 and RD45 .
I may also say that i have usb and aux in the armsrest.
Another strange thing is that i have greyed out the DEFINE VEHICULE PARAMETER.is that normal ?
- x 6947
The RD45 was a later version of the Basic RD4 and contained the bluetooth hardware inside the head unit. The RD4 as in your case needed a Nomad Bluetooth / handsfree unit that could be specified as an option back in the day.
That setting looks to be the setting for changing some vehicle options like rear wiper in reverse gear etc...
47vidm
Hi
I’m in need of some help please.
I have fitted the new screen, however when I pulled the rd4 out has two cables where the rd45 has one.
Thanks in advance
David
Thanks in advance
David
- x 1473
Can you take a photo of the RD4 and RD45 so that we can see what you are talking about?
47vidm
Hi yes no problem.
I have tried to attach a picture of each.
David
David
- x 1473
For both RD4 and RD45 there are several variants, some have a single antenna and some have two (or even three, but that is a different story).
The RD45s coming from China mostly only have a single antenna socket.
The RD45 with a single antenna should work OK, but the FM signal will not be as strong. I suggest that you try listening to a weak FM station with each antenna lead connected in turn to see which one works best for you.
47vidm
Great thanks I will try both leads as you suggest hopefully it will be ok.
