Hello there, my name's John and I'm new to this forum. I came here because of a strange issue. When I turn on the engine, the fans start blasting at max speed at 8/8 altough the display shows 1/8. Normally pressing the - button when at 1/8 would just turn off the heating/fans and the display, right now display turns off as usual but the fans still spin for some reason. Oh at this moment the displays also lights instantly when the engine starts. By default the display turns on only when I press a button around there. I've looked online for some fixes but the only similar thing I found is people not having their fans blowing air at all. If anyone knows a fix please let me know, the sound of the fans blasting at full speed all the time is deafening and can't even hear the engine or anything else inside or outside the car.
Edit: forgot to mention, increasing or decreasing the temperature works, but it still getting blown by the fans at max speed
Here's a little video I recorder of the problem in case it's easier to understand what I'm trying to deliver. Thank you for reading this!
Citroen C3 I (2002) - Heater/blower fans don't stop
ssilviu250
ozvtr
- x 253
Re: Citroen C3 I (2002) - Heater/blower fans don't stop
The fan is run by an electronic speed controller. Is is quite common for these to fail now that the C3 is getting a bit older. They can short circuit or open circuit, meaning the fan can stop running or run continuously.
The controller is located at the back of the air distribution box on the (in your case) the passenger side. It is identified by the two bright green connectors on it.
There are plenty of videos on youtube for how to remove it form Peugeot/Citroen cars.
Chinese knock-off replacements are available from Ebay but be careful of the quality. They can be DOA.
ssilviu250
Hey, thank you for your reply. I watched a video on youtube and went ahead and removed it so I can look up the serial number on it. Now when I turn on the engine the fans don't work at all (the display works tho), so it has to be this controller, otherwise I'd still have the same or even a different issue, right? At least now I can drive to a car parts store without my eardrums ringing. Right now:ozvtr wrote: 08 Dec 2021, 21:52 The fan is run by an electronic speed controller. Is is quite common for these to fail now that the C3 is getting a bit older. They can short circuit or open circuit, meaning the fan can stop running or run continuously.
I tried looking online for this controller using the "serial number" or whatever it is written on it (F657165W_L) as it can be seen below
but every site I end up on doesn't mention this code, they all have this "OE - 6441L2" whatever that means, like for example on this site (https://comnico.ro/cauta/6441L2__2/ordonare_pret-asc). Would buying any from this site be compatible with the version of my C3? Can I somehow check if this OE product will work using my VIN?
- x 6946
ssilviu250
Hello, thank you for your reply. Is it located in a different place? Because at the passanger's side (UK driver's side) I only found this - https://prnt.sc/22f8vwkGiveMeABreak wrote: 09 Dec 2021, 06:22 For a MK I C3 you need this Blower Control Unit:
https://www.ebay.co.uk/itm/192886968696
Also are these two parts, the one you linked and the one I linked, two completely different things?
This is my VIN in case it helps somehow - VF7**************[VIN obfuscated, can be read by forum staff]
- x 6946
Ok, so you have a late 2002 model which has the one you linked to above. The one I linked to is for models without A/C. Always better to have the VIN.
ozvtr
- x 253
Yes they are completely different. Yours has the electronic speed controller that is run by the digital display. The other type is for the 'manual' control panel, the ones with a fan speed control knob.ssilviu250 wrote: 09 Dec 2021, 07:25
This is my VIN in case it helps somehow - VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] (placed dots so it doesnt get censored)
ssilviu250
Update: I installed it back because windows were frozen in the morning and I had to warm it up. While driving to the store to order the new part, I smelled smoke and melted plastic and about 5 seconds later the fans stopped completely. Hazards on, parked the car and I quickly went ahead and removed the fan controller. After removing it, the smell and smoke went away. I sniffed the controller and it was reeking of burnt plastic. Continued on my way without it and placed the order for a new one, should arrive tomorrow. Is there any chance that a fuze also went down with the fan controller? Although the display still works.
- x 6946
You may have caught it in time - just try and get an original or good brand as a replacement - cheap ones are known to fail very quickly if they work at all!
ozvtr
- x 253
ssilviu250 wrote: 09 Dec 2021, 14:52 Update: I installed it back because windows were frozen in the morning and I had to warm it up. While driving to the store to order the new part, I smelled smoke and melted plastic and about 5 seconds later the fans stopped completely. Hazards on, parked the car and I quickly went ahead and removed the fan controller. After removing it, the smell and smoke went away. I sniffed the controller and it was reeking of burnt plastic. Continued on my way without it and placed the order for a new one, should arrive tomorrow. Is there any chance that a fuze also went down with the fan controller? Although the display still works.
ssilviu250
The new controller arrived today and I went to an automotive electrician to have the car checked just in case. I would have installed it myself if it wasn't for the smoke and burnt plastic smell, you can't play with fire. It turned out only the old controller got fried up and nothing else was damaged. Thank you everyone for your help!
- x 6946
No worries, lucky you sorted it in time.
