My turn for a C5!
citroenxm
Fallen Hero
x 70
Re: My turn for a C5!
Unread post by citroenxm »
Maps weren't that long updated when I had it James. The maps are stored on the head units hard drive.. I'm not sure if your age of headunit can be updated any further.
The sos my be a subscription service. Buy it sends an sos call to emergency services in the event of an accident. The right hand side is a sim slot to take your sim and turns the car into a giant mobile phone.
A very sad...
1994 XM 2.1 d auto
x 6946
You have the earlier RT4 system.
The last available maps update for this system was for 2016/17, which has data collected in the last 3 months of 2015.
https://citroen.navigation.com/product- ... enEMEA/GBP
x 3296
Is there a way (key presses, for example) whereby I can get the radio to show me what model/version it is?
citroenxm
Fallen Hero
x 70
No. You need to pull it out and see the model number on the sticker for head unit model.
As for maps. It should take the last one mentioned above James. It has the 2012 ones.
There's two versions of headunit which look identical on the outside. One with jukebox and one without. The one without jukebox needs the maps disc in the headunit all the time to work.. But with jukebox you don't need the maps disc as it stores it on the hard drive. That car has the jukebox and harddrive which was the last headunit offer on them before the c5 x7 came along
Furthermore harness for connecting them are different between non jukebox and jukebox cars so aren't directly interchange.
A very sad...
1994 XM 2.1 d auto
x 6946
As I mentioned you have the earlier RT4, but if you want to know the system firmware version try:
1) Switch the power on
2) Hold down the MENU button until you get the extended menu
3) Select DEVICE DESCRIPTION
4) The software version will then appear
This is what you do on the RT3 and the RT4 may well be similar on the older RT4
citroenxm
Fallen Hero
x 70
I can never Remeber the R numbers rt3 rt4 etc etc..
A very sad...
1994 XM 2.1 d auto
x 6946
I think the latest Firmware released for the RT4 was 8.31.
x 3296
Well, the radio is showing firmware version 8.31, and the UK map is 2016/2017, so all good there. However, she has a few glitches to sort out still (I will be doing a BSi reset either this evening or tomorrow). Neither the radio or the multiscreen show up on the Lexia (no dialogue with either of them), the BSi says there is an error with the oil system (F159), while the Injection is throwing up the error P0033. This afternoon she went into limp mode (2000rpm), but with no EML.
citroenxm
Fallen Hero
x 70
Are they codes from previous or was the car fully cleared after the work was done.?
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
Fault p0033 is bypass fault for turbo.. Possibly wastegate.. So possibly a vaccum electro valve like the mk. 1 C5 unless it's electric.. I'm not sure.
A very sad...
1994 XM 2.1 d auto
x 3296
I don't know, but neither of them will clear will clear.
x 3296
Where would I find the oil sensor? I want to check the wire is properly connected, and (if it is reasonably accessible) spray some contact cleaner into the connections.
Is the turbocharge purely electronically operated, or as there a vacuum 'component' involved? I want to resolve this turbo issue and I need to know where to start looking.
citroenxm
Fallen Hero
x 70
Oil level sensor. Is likely to be on the back of the block.
Not sure on the turbo issue.
A very sad...
1994 XM 2.1 d auto
x 8141
James, while I had my 3 2.2s I downloaded the service manual from the link below. It didn't solve all the issues but it was helpful in clarifying where things were etc. You may find it useful:
https://hostpdf.com/citroen-c5-2-2-hdi- ... ir-manual/
x 3296
I have had the Lexia back onto the C5, with my camera. The two errors are still there. F159 in the BSi, and P0033 in the Injection. They will NOT clear, which strongly suggests they are present when the Lexia is talking to her. Neither error was there when I checked her after the engine problem occurred (I have a little book with the owner manual that I record Lexia result in).
BSi error
BSi error
F159 description
F159 description
Injection error
Injection error
P0033 description
P0033 description
