Citroen 1.6 hdi engine block
Luke edgar
Hi all my 1.6 blue hdi con rods have bent and I need a engine block I am trying to find out if all the engine blocks are the same from 2009 to 2017 and if its just a matter of bolting my parts on it
- x 6956
Re: Citroen 1.6 hdi engine block
No, they have different part numbers between the 1.6 engines.
OnlinePaul-R
- x 1938
The con-rods have different part numbers or the block (assemblies?)?
- x 6956
I'm just talking about the blocks at present Paul. A couple of engines have the same block, but the other 1.6 variants are different.
OnlinePaul-R
- x 1938
Yes, I'm wondering why the OP is asking about a different block when he says the con-rods have bent.
(Further musings), all four con-rods damaged sounds like the engine has ingested water so maybe the block is damaged as well.
Luke edgar
It had dpf blockage and I can get an engine for it but it has different engine number to mine mine being the bhy engine the one I can get is 9hx
- x 6956
The BHY engine (DV6FD) 8 valve is far newer then your existing 9HX (DV6ATED4) 16 valve and I suspect there will be many other differences.
Luke edgar
Luke edgar
Is there any other engine blo ks the same
Luke edgar
I can ger a 9hx or 9 hp but need to know if they would do
- x 6956
Stick to the same engine code you have (9HX) to avoid issues.
Luke edgar
My engine code is bhy not 9 hx I want to see if the 9hx or if any other will do to go in a 2016 citroen c3 1.6 blue hdi
- x 6956
Ok, I mis-read what you said. Same thing applies, Stick to a BHY engine.
