x 8128
Re: Citroen and Peugeot Parts Requests
99xantia :welc: to the FCF, You could have a look at this, it fits in the passenger door mirror!! :)
https://www.ebay.co.uk/itm/221866711982 ... SwOdpXzFyx
x 6945
99xantia wrote: 26 Nov 2021, 19:33 Hi
I’m lacking on ability to find a parts catalogue I can download anywhere so can anyone tell me the correct part number for an external temperature sensor for a 1999 Xantia 2.0L HDi 109 please.
Any pics/part numbers would be great. I don’t even know where to look for it! I’m new to the Xantia.
Many thanks.
Please see the first post on this thread:
viewtopic.php?p=685750#p685750
x 6945
Mark Graham wrote: 26 Nov 2021, 19:16 Hi all,
looking for help on a throttle position sensor for my Peugeot 605 2.1 auto. Reg number t184twk Really struggling to find one, im not sure if it would be shared with the xm?
I did manage to find a used one online but it was from a manual car and its different on an automatic.
If it's item (7) - The Accelerator Pedal Sensor, then it was part number: 1622F2, but no longer available from PSA and I can't see anywhere from a brief search. So is it worth contacting a specialist to see if it can be refurbished?
Rhothgar
(Donor 2026)
x 221
Unread post by Rhothgar »
It seems I am getting great value out of my donation. Not sure if that is a good thing...
I've sifted through all the messages on here to see if it's been asked before. Nope but I got a little excited when I saw the rear subframe with torque settings.
So! Please may have the fiche for the rear subframe which shows the mounts for M728 GDL?
Thank you in advance Marc.
x 6945
I'm not sure exactly what you want - the subframe shows no flexible mounts - so are you referring to the engine mounting?
If anything here, let me know the item number.
Rhothgar
(Donor 2026)
x 221
GiveMeABreak wrote: 27 Nov 2021, 10:03 I'm not sure exactly what you want - the subframe shows no flexible mounts - so are you referring to the engine mounting?
Rear subframe, Chief.
x 6945
There isn't any rear subframe listed - that 's the issue - so what do you want? Rear hubs / Rear Axle or rear bump stops for the suspension? It's an issue of terminology I suspect.
Rhothgar
(Donor 2026)
x 221
GiveMeABreak wrote: 27 Nov 2021, 14:28 There isn't any rear subframe listed - that 's the issue - so what do you want? Rear hubs / Rear Axle or rear bump stops for the suspension? It's an issue of terminology I suspect.
This baby please!
x 6945
Rear Arms and Hubs. The diagram you posted was for a Peugeot 206, the Xantia doesn’t have anything like this. Hopefully this is what you need.....
Rhothgar
(Donor 2026)
x 221
Here you go, Marc.
Definitely a subframe.
This photo is from one of Jim's posts. You can ignore his green arrows. You can see the bush or front flexible mount as I believe it is called. It might come under steering? Jim says Mk. 1 Xantias have rudimentary rear steer.
x 6945
Ok PSA servers are down for updates at time of looking , but here's one I prepared earlier: For reference, it's officially called the 'Suspension Crossmember Torsion Bar Recess Door' :-D
Rhothgar
(Donor 2026)
x 221
Oh dear! Part A - NFP.
Can I have the part numbers when available for Parts A, B and 5 together with any dimensions of Part A. Thank you Marc.
x 6945
Indeed.
I did have a quick search on Spareto and although the originals are no longer manufactured, they did show 2 other units with compatible part numbers - so may be worth making an enquiry, link here:
Part number was 513175
https://spareto.com/oe/513175
Rhothgar
(Donor 2026)
x 221
Oh dear. Care could be a write-off after all I’ve done to it recently!
I have a master plan though to silicone it up to form it up if worst comes to the worst plus CitroJim has an old subframe with some in. Getting them out will be the challenge though.
Whilst on the subject of bushes, what are the part numbers for the front wishbone bushes please?
x 6945
The only one Citroen supply separately is item (9) Wishbone bush, part 96083570 £22.15
The other bushes are supplied as part of the actual wishbone item (2) which includes the item above and 'B' & 'C', parts:
OEM = (Citroen Original)
Left: 3520C1 (No longer available)
Right: 352181 (No longer available)
Citroen Cheaper Alternatives:
Left: 1607312780 £147.94
Right: 1635775380 (No longer available)
But again - have a look on Spareto using these part numbers as they have a selection of alternatives. Make sure you look at the bottom of the pages where there is a tab that says OE numbers. This will list the Citroen Part numbers for the items for cross reference. I would always email to check with them too.
https://spareto.com/products/febi-bilst ... -arm/19121
