206cc
For an £80 punt i got a 1.6hdi 206cc no mot due abs,esp lights on dash , it drove good but failed because of the lights.
From April this year i replaced the complete braking system changed all the abs sensors as they were reading incorrect ohms, I then had full clutch kit conversion followed by headgasket full engine decoke new glow plugs which revealed two tips snapped in the head but easy removed because the head was off.
I then had two new tyres fitted as the rear were crap.
I had all new filters and fluids done and reset the warning lights .. All done. Till the mot day drove 40 yards up the road all the lights came on the dash and z rumble noise from ns front wheel so i turned round and came back home cancelled the test.
The noise from the ns front wheel was bearing so i purchased a new one pressed out the old bearing to reveal a damaged hub , new hub purchased and new bearing, all new fitted and 3 failed bearings later i had the new hub carrier measured to find out it had been machined wrong it was 80mm going out two 81mm so this all went back and money was refunded .
A recondition complete hub with bearing was purchased and fitted and that solved that issue.
I had diagnostic which said ns sensor open or ground with speeds reading over 180mph while car sat in the drive unplugged the sensor it tested normal tested the loom ... no signal.
Unplugged loom to abs pump signal came back after plugging it back in then lights off only to come back on on test drive, left the car for a couple of weeks and then decided to dig further into the looms
Took off the loom to abs pump 4 wires were rubbing the inner wing along with one white wire snapped
Soldered all back together heat shrinked the joints and doubled taped the whole loom back together
Tested car again lights still on now with code for both rear sensors open or ground to earth.. found the last bit of the problem where I'd probed the connector block the female side was opened that wide the pins of the male didn't contact, squeezed the female pins in plugged the connectors back together ... All lights off computer reveled no codes.. mot 2 days .. fingers crossed.
206cc abs esp faults finds and FIXES !
Huskyxantia
- x 876
Husky.
Huskyxantia
- x 876
Re: 206cc abs esp faults finds and FIXES !
It passed the mot test today and no advisories
Husky.
- x 3299
Yay!!!
Huskyxantia
- x 876
Urgent
Who knows the proper torque of the front bearing hub nut for the 206cc 1.6hdi ?
Driving me mad ots all different on the web
Husky.
Huskyxantia
- x 876
Abs wire colours blue,white red,white rear. The loom to abs pump bends this is were the breaks were .
Husky.
Huskyxantia
- x 876
SOMETHING NEW.
So i roll the boot blind back to put something small in the boot
Then roll the blind back then go lower the roof & all i get is deeps so popped on the scan tool get the code as per photo but heres the best bit when the code is wiped the roof works.
Reason: Image rotated
Husky.
