Citroen c3 Picasso rear window blinds
Bry
Unread post by Bry »
HI, new to the forum. I’m looking to see if anyone knows an easy way to get the rear window blinds off? I had a look and it looked like you have to strip the window rubber off.
x 6957
Re: Citroen c3 Picasso rear window blinds
Hi and welcome to the Forum.
No, but there is a technique to removing them.
I'll dig something out if you can check back in 20 minutes or so....
x 6957
Here you go:
You'll need some trim removal tools.
Open the rear door and lower the glass to lowest position.
Unroll the sun blind (1) (Maximum).
N.B.: Do not attach the sun blind (1) to the hook (2).
Position - Hold: The sun blind (1) (as "a").
CAUTION: Respect the order of removal.
Undo the metal fastener (at "b") by pressing on the plastic clip (as "c") using trim tools.
N.B.: Two operators are necessary.
Proceed in the same way for the clips ( as "d", "e").
Remove: The sun blind cassette (3).Refitting:
Position: The sun blind cassette (3).
Clip: The sun blind cassette (3) (as "b") (In the direction of the arrow ).
Check all the equipment works.
Bry
That’s great thanks. Thank you
BarneyRubble
x 6
Unread post by BarneyRubble »
Getting this sun blind off was very difficult and, not gonna lie, I failed. If you're re-inserting the door card because you took it off earlier, you can slide the door card under the blind if you push the blind up, and do not engage the inner door handle lugs until the door card is in place. Then you can slide the inner door handle into position and bring the card home. One other tip too is to put all the white door clips into the door card first and then re-fit the door card. Three screws and you're done.
