Hello!
I drive a x7 manuell 2010. Vin VF7**************[VIN obfuscated, can be read by forum staff].
I am about to buy new drive shafts due to broken dust covers (cv joints). In my search I find 2, and sometimes even 3 different shafts for each side. I presume for automatic and manuell gearbox. Wich ones are the right ones for me? Are there any original parts numbers?
Drive shaft original part number
- x 6947
Re: Drive shaft original part number
Here you go Gustav:
Left: (1)
Citroen OEM: 3272RV £517.60
Citroen Cheaper: 3272RW £301.39
Right (2)
Citroen OEM: 9812139980 £517.60
Citroen Cheaper: 3273SJ £301.39
Left: (1)
Right (2)
gustav
Hello again!
I am a bit confused. There are 2 different alt for oem 3273SH? https://www.sparepartstore24.co.uk/oen- ... B%5D=10668
The same for oem 3272rv? https://www.sparepartstore24.co.uk/spar ... &type=ajax
- x 6947
The part numbers we provide are for Citroen original parts - not for aftermarket parts, so I can't help you there Gustav. These part numbers are for either Citroen original equipment as fitted to the car when new or Citroen's recommended exchange units which are a bit cheaper.
But be aware - as you can see you take a chance with aftermarket 'equivalent parts', as the sizes between the 2 on the spareto site are different!
