BSM Connector removal
adrian0011
Unread post by adrian0011 »
Hi,
I am working on the replacement of the BSM of my beautiful Citroen C5 from 2005 (type BSM 6500CK).
I have difficulties removing the central connector. Could someone help me please? How can I remove it?
Many thanks!
BSM 6500CK
BSM 6500CK
BSM 6500CK
BSM 6500CK
x 1056
Re: BSM Connector removal
Unread post by wheeler »
Theres a little plastic tab on the connector that you use a small screwdriver or similar to pull back in the opposite direction to your arrow whilst you pull the connector out. It very straightforward.
adrian0011
Well, this will do. Many many thanks wheeler!!
adrian0011
connector loose1
connector loose1
connector loose2
connector loose2
