Rear strout/cylinder rubber protector for C5X7???
Gregor
x 16
Unread post by Gregor »
Hi.
Does anyone know where to get rubber protector for rear strout on C5X7 (Hydractive 3+). Right one is broken but citroen doesn't sell that part at all (just as a complete replacement set with new strout)????
Part 10 or 16 on attached foto...
Driving Citroen is a diagnose!
x 6948
Re: Rear strout/cylinder rubber protector for C5X7???
No, as you say Gregor, unlike earlier models that had separate boots, these are all-in-one struts and the rubber I believe, is bonded!
Sloppysod
x 400
Unread post by Sloppysod »
This is an unproven suggestion, but, is it repairable with bicycle innertube repair patches?
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Gregor
x 16
Maybe it could be, but access is problematic without striping all down. Too much of work for test only purposes only .... I was hoping that someone knows if any company is producing this as a spare part, but looks like no one does.
Sloppysod
x 400
GiveMeABreak wrote: 15 Oct 2021, 21:57 No, as you say Gregor, unlike earlier models that had separate boots, these are all-in-one struts and the rubber I believe, is bonded!
Will one from an earlier model fit?
Cut the damaged one off and fit the replacement with suitable clips or adhesive.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6948
I can't see that working Stu - they are completely different sizes and apart from that, the older C5s had leak back pipes with the connections on the boots - the X7 doesn't.
x 1945
Block off the leak-back pipes or holes that they leave?
x 6948
But the earlier ones are just not long enough....
C5 MK I/IIC5 X7
Best of luck though if you are going to try it.
x 1945
The suggestion was more in hope than expectation. I'll not suggest gluing two together to get the extra length then... :rofl2:
x 6948
I'll save you the bother:
x 1945
I see nothing wrong with that...
Sloppysod
x 400
GiveMeABreak wrote: 29 Oct 2021, 14:19 I'll save you the bother:
Paul-R wrote: 29 Oct 2021, 22:15 I see nothing wrong with that...
Apart from the knots could do with being a bit tighter or even doubled. :rofl2:
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 5678
I wonder if a steering rack gaiter could be adapted, some of them are quite long and around the same diameter.
Gregor
x 16
Nice try guys. At least you have made me smile!
x 6948
:-D
