2016 C4 Picasso Abs, esp, parking brake and tyre inflation monitor faults showing
tomaskriv
(Donor 2026)
x 6
Re: 2016 C4 Picasso Abs, esp, parking brake and tyre inflation monitor faults showing
Unread post by tomaskriv »
Looks like cleaning helped. Errors gone.
x 6957
Nice one! Keep an eye on it - but they can get dirt / water inside - unsurprisingly considering how exposed they are!
tomaskriv
(Donor 2026)
x 6
Thanks for help!
tomaskriv
(Donor 2026)
x 6
Well....all came back thisorning....
x 6957
Ok, so you may well have a loose pin or bad connection in the socket - so looks like you may need to get it replaced after all if the same fault codes are reappearing.
tomaskriv
(Donor 2026)
x 6
I just hope it is not some damaged wiring somewhere. I am waiting for new sensor to be delivered today. Fingers crossed. I hate to see warning lights on the dash.
tomaskriv
(Donor 2026)
x 6
Replaced the sensor. Lights still on. Connected DiagBox v7.62. After clearing faults I still have C1391 00...
Engine ECU not recognised. Good few modules were like that. Is this software or I what?
x 6957
Where did you get your VCI unit from? ECUs not being recognised can be indicative of a non-full chip kit, usually found on the less expensive Lexia kits.
tomaskriv
(Donor 2026)
x 6
Paid €90. Said full kit. Might be not.....
x 6957
Sounds around the right price for a full chip - but it can be a bit hit and miss.
tomaskriv
(Donor 2026)
x 6
Friend at work has Autel tool. Will try that one. Hope it will reset that DPF aditive warning for me.
My Lexia managed to delete all errors from ABS module. I hope it will stay that way.
Maybe you know whitch is the best tool for around €300-€400?
tomaskriv
(Donor 2026)
x 6
Small update:
Fitted new sensor and erased errors.
Nothing pops after engine start. Now I have ABS /ESR error after some driving. Sometimes few miles and sometimes 15-20 min. Errors appear in two stages. Abs/Esr and after some time Tyre pressure, Handbrake, Hill assist etc.. After 2nd batch of errors appers, GPS frozes.
tomaskriv
(Donor 2026)
x 6
Looks like damaged wire....
What is the way to troubleshoot this? Check continuity? Is wire from ABS rear sensor goes directlyto ECU?
tomaskriv
(Donor 2026)
x 6
Hi Marc,
sorry for disturbing you....
Could you help me with my ABS issue. I want to check continuity of rear right ABS sensor. Does the wires from sensor go to ABS ecu? If yes, what pins. Thank you.
x 6957
Leave it with me for a second....
