Zoe antifreeze
This is the Forum for all your Renault Technical Questions, Problems or Advice.
x 2943
Zoe antifreeze
Is it anything special?
I've got blue and pink stuff on my shelf, do I need something different?
x 7162
Re: Zoe antifreeze
AutoDoc when you put your reg in comes up with this page of compatible Anti-Freeze. From the reg it classifies you car as a RENAULT ZOE (65 KW / 88 HP)
https://www.autodoc.co.uk/car-parts/ant ... /55132-zoe
x 2943
Re: Zoe antifreeze
That looks ok Neil the yellow Valeo stuff might be what's already in there. Thanks.
x 7162
Re: Zoe antifreeze
The coolant system may well have a special architecture as with the Zoe it helps with thermal management of the battery. The reservoir for this may be locked, it is on some EV's, and should never need topping up.
Edit not so sure thats the case for the ZE 20 may just be the motor. The Active thermal Management System of the Zoe ZE20 Battery pack, may be Air-Cooled from the AC system.
x 7162
Re: Zoe antifreeze
This coolant thread gives some useful insight from users. :-D
https://www.speakev.com/threads/coolant ... st-2953230
