Saxo gearbox arm
Jonathancilia
x 9
Saxo gearbox arm
Unread post by Jonathancilia »
Hi, im on the mission to tighten up my saxo gear linkage, the arm that attaches to the gearbox with a pin is ovalised,any idea where i can find a new one or one in good condition online preferably?
Cannot find anything locally and way back there was one on ebay buy it got bought immediately
x 6955
Re: Saxo gearbox arm
Is it the gear shift rod you need?
If so, these are available from Citroen Classic Parts for around 32 Euros.
x 1044
Unread post by wheeler »
Im guessing its part C? The pin (31) works loose over time & if you ignore the sloppy gear change it can cause the pin hole to go oval.
Jonathancilia
x 9
wheeler wrote: 09 Oct 2021, 10:16 Im guessing its part C? The pin (31) works loose over time & if you ignore the sloppy gear change it can cause the pin hole to go oval.
Yeah thats the one i need but mine only has 1 ball on it not two. Cant find any new ones mine has become oval and new pin will not solve the problem
