Morning,
Looking for the part no's for the left and right front support pivot arm on my C5
I believe the left or nearside no is 96 615 440 80.
Kenny
Part no's please
KennyW
- x 163
Part no's please
C3 1.4 petrol (SWMBO)
- x 6954
Re: Part no's please
That's not a valid part number Kenny and doesn't bring anything up.
'B' (2) is called the Front Pivot Support
365604 (left)
365704 (right)
or (7) is called the Front Axle Triangle Front Arm
3520N8 (left)
3521J8 (right)
365604 (left)
365704 (right)
3520N8 (left)
3521J8 (right)
KennyW
- x 163
Thanks Marc,it maybe the Peugeot number.
How much are they from Citroen ? This is going to hurt !
Kenny
Kenny
- x 6954
I'll advise you Sunday - parts are down for updates at the moment Kenny - who knows may be a bit cheaper tomorrow!
(unless they're coming from France on an HGV - in which case, you can probably add a few hundred quid on - especially if it's like any of the profiteering petrol stations who are whacking their prices up 15p a litre!
- x 6954
Here you go...
What could be wrong with the actual Pivot Support? Unless it's cracked or otherwise damaged, surely a bush replacement would cure any issues? I had my lower support arm bush replaced where it attaches to the wishbone as that was slipping back and forth under braking / potholes / bumps acceleration.
365604 (left) £441.94
365704 (right) £441.94
3520N8 (left) £75.30
3521J8 (right) £75.30
KennyW
- x 163
Ouch, just as I suspected.
Marc,
The bush is moving out of the Pivot support. Hence my inquiry re new. Also the additional questions on my previous post re the wishbones.
My FNS wishbone rear bush was badly deformed. It is bent from round to oval. I'm thinking the housing is also oval.
I have obtained a 2nd pivot support which was on a Peugeot hence the part no mentioned.
As far as I can see and measure this support is fine but I am changing all the bushes for new on this one.
I shall get back to the forum once changed and any observations seen on my original unit.
Kenny
Marc,
Kenny
KennyW
- x 163
more part no's
Afternoon All,
Looking for the part no's for the top suspension mounts or bearing mounts as Citroen call them.
I've got 352715 & 352714 but also seen 964470388C.
Can these be confirmed or updated ?
Also cost of each ?
My wallet will hurt again.
Kenny
Also cost of each ?
Kenny
- x 6954
Re: more part no's
These are called Axle Arm Bearing Brackets item (10)
352715 Left
352716 Right
They are £207.26 each inc VAT.
The other number isn't listed Kenny, so can't confirm either way.
352715 Left
352716 Right
KennyW
- x 163
Re: more part no's
Thanks Marc,
What long winded name for mounting bracket.
Sorry for all the part requests just keeping myself ready for any difficulties ahead.
Do you think it would worth while adding these part request posts to my front wishbone post as they are all related
Kenny
Kenny
- x 6954
Re: more part no's
Yes, just use the same post Kenny - that keeps it all together as I'm notified of each post, so will check it to see if it's a discussion or a new part request
In fact, I'm going to merge this post with the other thread just so you know.
KennyW
- x 163
Great Marc, I’ll put them on the original post as a link when I get home tomorrow
- x 6954
I’ve merged the threads now Kenny, so just tag on any other of your X7 parts requests to this thread
