Fault
Georgeoldfield83
Fault
Unread post by Georgeoldfield83 »
Citreom c4 grand picasso 2015 keeps coming up with electrical circuit fault repair now, jas anybody got any ideas
x 6956
Re: Fault
Hi, not really, not without a diagnostic being done - electrical errors can be any multitude of issues, so a proper diagnostic with modern cars is really essential these days to get some pointers.
Georgeoldfield83
Re: Fault
Thank you I had a battery swap at halfords yesterday and asked them if they had programed the car to the battery. They said you didn't need to, after a bit of back and to they put it on the computer and it has 3 faults.
B1624 supplies protection and management unit central Power switch positive relay status fault
B162C accessories positive relay control and status not coherent
C1406 engine or power steering calculator overtemperature not characterised
I think it will need to go to the main dealer
x 6956
Re: Fault
B1624 has 2 more numbers after the main fault - these determine whether the relay fault is because it is open or closed. But in either case the relays are the issue.
As for the power steering fault - this is due to an overheating condition of either the Power Steering ECU or the Power Steering Motor. Whilst this fault is active PS assistance can be reduced by 60%. So you may experience it being stiffer to turn.
I would first get the relays looked at as there may be a lack of power getting to the PS ECU as a result of a knock on effect and it trying to work harder on reduced power...
x 1056
Re: Fault
Unread post by wheeler »
Has the issue only started after replacement of the battery?
Did they try to erase the fault codes?
citroenxm
Fallen Hero
x 70
Re: Fault
Unread post by citroenxm »
GiveMeABreak wrote: 30 Sep 2021, 12:01 B1624 has 2 more numbers after the main fault - these determine whether the relay fault is because it is open or closed. But in either case the relays are the issue.
Hi marc .
I have this charging issue on mums picasso .. but.. where are these relays that are spoken about. I notice the fault is in the bsi section .. on mine its reporting relay closed. But what relay ?
Thanks.
A very sad...
1994 XM 2.1 d auto
x 6956
Re: Fault
Which exact vehicle is this Paul, better still the VIN would save me a lot of hassle. I'll take a look at the circuit.
citroenxm
Fallen Hero
x 70
Re: Fault
Marc. Scrap that. Id sat with it idleing a few.times and check altinator output on diagbox which was a healthy 14v went in the house 30 mins later went back out and it was all gone.
My other issue is steering wheel angle sensor but thats better another post.
A very sad...
1994 XM 2.1 d auto
the old chap
New User
Re: Fault
Unread post by the old chap »
I had the same problem. I got a charging fault message. I was getting 14.45 v with the engine running. Left it for a week and it was dead. Got a diagnosis of the BPGA unit. It has a relay which is shorting to earth and draining the battery. A very crude check is to flip the positive clamp on the battery. I got a spark which was bigger than it should be, possibly showing something is draining it. I was losing about .5v per day.
Sele001
New User
Re: Fault
Unread post by Sele001 »
Hi guys,
i have a similar problem on my citroen c4 picasso 2015.
It was showing me an electrical fault when starting. After a few days the battery died. After charging, everything is ok no massage. I go to the service center, they say the fault is BPGA2010. More specifically, B1624 73 (Central power switch plus relay status error). Apparently, I need to replace the entire module because they can't fix it. What do you suggest, should I try to replace only the relay or ...?
yijie
New User
Re: Fault
Unread post by yijie »
Sele001 wrote: 20 Dec 2022, 18:07 Hi guys,
Hello Sele001, I am having the exactly same issue. Did you fix this at the end? Could you please tell me what you did? Thanks.
x 6956
Re: Fault
These modules are usually self-contained and if there's a fault the unit should be replaced. They're not designed to be taken apart.
ShadowOfDest
Re: Fault
Unread post by ShadowOfDest »
Hi guys for 4 weeks i have the same problem i get this error after i replaced the battery saying battery charge fault. Stop the vehicle, but this error comes and goes. Ive checked the battery and the alternator at a shop and said that both are fine. Ive managed today to catch the error on my scanner and its a c1406 error. Could anyone help? What you guys done to fix it. Where to start from. What ive done so far is either reset the battery by disconnecting it. I mention that alternator and batteryare fine as they been checked. Or sometimes dissapears on its own. Thank you!
