Time and Temperature Display
- My Cars: Citroen C$ Picasso 2015 1.6L Automatic
Have a Citroen C4 Picasso 2015 and trying to fit a Sat Nav to it. Have change the Display to one with a Sat Nav switch on it and the Multi Media Unit to a 98 104 863 80 Dated 2015/09/06 and had it initialised and all working OK except that I have lost the Time and Outside Temperature display. The Time was automatically set correct on start up but any idea's as to how I can get the Time and Temperature to be displayed.
- osx
- Lexia Available: Yes
- My Cars: GSA X
BX 1.6
C5 X7 Auto
C5 X7x2 Manual - x 15
Re: Time and Temperature Display
Have you tried Mira scripts?
C5 X7 Exclusive 2.0 HDi Auto
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5728
Without knowing what system you had, what you have fitted there's very little to go on. Have you fitted a PSA telematics system and if so what is it?
The car is a 1.6 l TDI picasso automatic 2015 reg and I have changed the multi-media player behind the display for a 98 104 836 80 dated 2015/09/06 and had a garage mate it to the car, everything work less the temperature and time display. Not very impressed with the Sat Nav so have reverted ti original and use a stand alone Sat Nav when required
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
These systems are not designed to be swapped without checking compatibility and simply VIN coded alone. Each system can display data in a different way as they are cross-range systems and what is designed for Peugeot won't automatically work straight away in a Citroen for an example.
Each can display options and data streams in different manners according to the vehicle it is installed in. One example - Peugeot can have a retractable display, Citroen doesn't, some systems display certain data in a different location. All these things have to be configured in addition the the VIN when changing the default telematics units.
