RNEG swap to RT5
silvering
Re: RNEG swap to RT5
Well, for now i will use this one. Till i can get my hands on an rt5 unit. Does the forum has buy/sell section? After i get rt5, i will sell the rneg and this unit..
- x 6957
silvering
So, what happened is, i got RNEG2 eMyWay purely by luck. Installed, all works fine and dandy. But somehow im still not satisfied
edit: i will soon publish the other two units for sale
silvering
Ok. I have a question. I did a straight swap. It works, mostly. Updated the map for Scandinavia. With it it should have updated the risk areas i think. But for some reason the option for managing the risk areas is greyed out. Also, all others rt6s i've seen have the map in 3d, mine is in 2d.
Otherwise all works good. Trip computer is showing. Temp and tpms page doesnt want to, but thats maybe cause i dont have tpms and i have disabled the function with diagbox. It reacts fast, it was a sh***y job to parse the usb cable.
Maybe some tweaking with diagbox is needed? I only coded my vin..
- x 6957
Risk areas are separate - you can get these quite cheaply from SCDB:
https://www.scdb.info/en/plugin-peugeot-rt6/
You don't have TPMS on your vehicle, so that's why it won't display.
Map options have to be set from the navigation screen.
- x 1939
@silvering I sent you a PM last Tuesday which hasn't been picked up yet.
