since i didnt find any disassembly of safety valve, so..
and in this case the o-ring that Kept by cold formed edge of sensor housing is pushed out by lhm fluid pressure!! and it can cos leak
xantia safety valve
Re: xantia safety valve
Hello... I'm a little late to ask. Is there any advice or recommendation on how to get this out of the car?
It seems very complicated in the CT motorization. Maybe some photos?
Thank you
Thank you
it is under LHM reservoir in left hand steering non-hydractive xantia. disconnect hoses and remove reservoir and then u will be able to see it better.
