Ds5 H4 strange problem
- My Cars: C3 picasso
Hi to all and thanks for reading.
I have a Ds5 H4 , was leaking on one injector, took the injector to clean the gunk and replace the seal.
Now p1631 and p2150 present, rough idle but no smoke, completely unoperable.
The injector i took out have a bit of higher injection time 147ms vs 121 of the others.
Any ideas?
Any ideas?
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5726
Re: Ds5 H4 strange problem
Pop your VIN up, I'll have a check.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, so here you go:
I would start with P2150 first as the P1631 may be as a result of the other fault. This should give you some pointers.
Fault Code: | P1631 |
Description of Fault: | Computer: Internal fault (injection with no load). Fault internal to the engine ECU on the torque calculation functions, detected for 2s. |
Conditions for Fault to clear: | Driving with the engine hot for 5 minutes. |
Downgrade Modes whilst Fault is active: | None Listed |
Symptoms: |
Suspect Areas: | Engine ECU |
Fault Code: | P2150 |
Description of Fault: | Injectors control: Injection bank 2: Voltage too low. Voltage of injection bank 2 too low for 5 seconds. |
Symptoms: | Warning lamp MIL "SERVICE" warning lamp
Suspect Areas: |
Yes, its more or less what duagbox said, but im still clueless of why this will happen on mechannicalli removing an injector to change the seal
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Well as recommended in the suspect areas, it's possible the electrical connection has been damaged or the fuel injector itself on removal.
Well the cables themselves have seen better days, however continuity its fine, i have seen in diagnox the (i dont remember very well now) correction of acyclisme was +120 for the one i removed and -40 around for the others, that maybe pointing the injector? Can you confirm they are embr00101d? All stickers gone covered in gunk so cant read any codes on them .
Will be coded ones i believe.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
I can only provide you with the internal PSA part: 1980L3 (New) for the injector and holder or 1608902180 for an exchange injector / holder.
What do you think about that acyclism correction?
Should i go for an injector to test?
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
I can't advise you on that as I'm not an expert on effects of acyclisme correction on injection systems to prevent vibration - but something has obviously happened since its removal and replacement. You may well find a diesel specialist who can help further and not settling down.
You might try a proper shut down and restart first though:
BSI Reset / Battery Disconnect / Reconnect Procedure
Pay particular attention to keeping everything shut and the timings to give the ECUs and the data networks time to sleep.
Good, will try the harness, the injector mada no difference.
Do you think you can find an schematic of the harness?
Hi, well as i said, replaced and coded the injector ,no change.
Tested wiring from ecu to injector plugs, all wires 1 ohm or less.
I may missed something when you posted the description of the faults. It says there that condition to clear, driving with the engine hot 5 minutes.
That actually means it may clear driving? As the misfire its as horrible i havent tried, but can do
Well, still flabbergastered whith tis car, after successive bsi resets, sometimes faults go, at least, car starts without missfire, but instantly come back with the p2130, however running well, as soon as i clear the fault it start misfiring again.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Are you using Diagbox for the diagnostic? Reason I ask is that P2130 is not listed as a fault code against this engine ECU.
Generally and not specifically speaking in relation to this car, the P2130 would refer to a Throttle Position Sensor anomaly. P2132, P2133, P2134, P2137 & P2140 relate to TPMS issues on this engine.
Sorry , my fault, p2150, and after a short deive which started well but ended horribly misfiring, p12A8 p12a5 and p1631
