So, this car has it’s in-display light flashing nonstop. Is there a way to fix this? I have a YouTube video that shows the display flashing nonstop.
Thanks in advance!
Citroen C2 2008 display flashing
ozvtr
- x 253
Re: Citroen C2 2008 display flashing
The date and time have not been set.
My guess is that the stock radio has been removed and an aftermarket radio installed?
If not, refer to your owners manual to set the date and time via the radio buttons.
- x 1746
Hi, and welcome to the forum.
The flashing is almost certainly because you need to set the time/date. Usually happens after a battery disconnection.
Amincroes
Hi thanks for the reply. The car has an aftermarket radio installed.. that makes sense because I couldn’t find the buttons to set the date and timeozvtr wrote: 01 Sep 2021, 04:56 The date and time have not been set.
Amincroes
Hi, thank you for the welcome.white exec wrote: 01 Sep 2021, 07:07 Hi, and welcome to the forum.
There is an aftermarket radio installed. Is there still a way to still set the date and time?
- x 6946
No
The head units are not just radios, they have other functions and you will have lost other functionality like being able to configure vehicle options as well.
- x 1055
It may depend on the spec of the car. I had a C4 which i fitted an aftermarket radio to with the slighty higher spec central display. I could still adjust the date & time using the steering wheel controls.
