Hello there,
Last saturday, while driving over a mild bump, my C5 has shown "ESP fault" on the console. I got home with no further issues.
The day after, I started the car again and there were no issues, thus I went with it and started driving. 2km from home, after I drove over the railroad(10kmph), "ESP faulty" error popped up again, followed by "Break faulty", "Engine Faulty" and plethora of others. I returned to home straight away and turned off the car. After that I didn't manage to turn it on again, even though Ive tried multiple times(nothing happened when I tried to turn the engine on, there were multiple beeps when I gave the contact). Car got into an economy mode quite fast that day. Even when I called mechanic with the power booster, we couldn't start it. Thus I towed it to the car electric.
After inspection, car electrician said that errors are coming from the BSI unit and that BSI unit itself has to be replaced. Now, ive checked the parts market and there are dozens of used BSI's but I am not sure if they will fit or whether they can be changed so easily?
Mine unit is BSI 2004 H05-1 060207. THere are more codes on it, BOOT, HARD etc. Also there is V02 - 00 , I presume it is version.
Can I buy any working BSI with BSI 2004 H05-1 designation and V02 -00 version or there is more to it? I've noticed Peugeout 407, 307 and C4 share the same BSI, at least BSI 2004 H05-1 designation. Also, there is a plethora of BSI units from the newer C5 model(2007-2015) but even though on pictures they look the same as mine, their designation is different, so I presume those wont fit into it.
I am working in IT with computers and servers thus versioning and complexity behind it is quite familiar to me, but I know nothing about the cars sadly...
EDIT: I forgot to mention, this issue happened to me 2 and a half months ago as well, right after I bought the car, but I've managed to turn on the car from like 20-th try and I drove it to the mechanic, he said that it was not a mechanical issue and that I should go to the car electric, thus he erased the errors(without my knowledge) so I would not have an issue with ignition, but of course, when I went to the electrician he said there were no errors for him to work with thus I continued to drive the car, waiting for the issue to happen again.
BSI replacement C5 I Phase 2 2007 2.0 136 HDI
- x 1055
Re: BSI replacement C5 I Phase 2 2007 2.0 136 HDI
First off im not sure if you are aware or not but if you fit a used BSI from a different car the car will not start unless you also replace the engine ECU & a working transponder chip all from the same car? Also if the used BSi has more kilometers on it your car will inherit the higher kilometres.
What makes them think the BSI is faulty? BSI failures are actually quite rare.
NoHeal4u
Electrician said he tested minor modules(ABS, ESP ... etc) first and that main source of error seems to be the BSI in the end. But as I said, I have almost no knowledge on cars, so I couldn't discuss this in more details with him last time we spoke. I started educating myself on this topic yesterday.
- x 1055
Who is the manufacturer of your BSI?
I have checked quite a few variations of the MK2 C5 & there only appears to be one part number for the BSI no matter which engine you enter suggesting that all the MK2 BSI's are the same?
Dont try to use on from a MK 3 (2008 onwards) as they are different.
NoHeal4u
It appears to be Johnson Controls .
leithant
- x 9
I'd be checking the BSM first.
06 Citroen C5 Estate 2.2 Hdi Auto
95 Peugeot 306 S16
95 Silver Xantia VSX - now deceased
95 Peugeot 306 S16
- x 1939
Those are photos of a BSM (fusebox) not a BSI aren't they?
- x 1055
Nope, Definitely the BSI in the pics above.
- x 1939
There's certainly a lot of variation in what BSIs look like! I can only compare it with the BSI from our 308. All metal enclosure and no fuses.
- x 1055
Ive never seen a PSA BSI thats metal or without fuses. Do you have a picture of one?
- x 1939
I think I may be even more confused than usual. This is an engine ECU, not a BSI, isn't it.
- x 1055
leithant
- x 9
yes, that's BSI.
95 Peugeot 306 S16
95 Peugeot 306 S16
NoHeal4u
UPDATE:
Problem was solved. Although, first replacement BSI which Ive bought didnt work(it was from Peugeot 307 even though serial number was the same like my old BSI, thus hydraulics and remote locking didnt work correctly) , second BSI which was from different series but same model H05-01 worked without issues.
aneesh84
- x 29
Did you have to pair it with the Engine ECU? you just replaced the BSI or other ECU, transponder, keys with it?NoHeal4u wrote: 17 Sep 2021, 14:35 UPDATE:
I have been having multiple errors, sometimes intermittant. I am also suspecting the BSI.
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
C5 2005 2.0 HDI 138
