3008 MK1 powerfold mirrors retrofit
- x 6960
Re: 3008 MK1 powerfold mirrors retrofit
Yes, but PSA have their own internal part numbers and they are different, so I can't confirm that the part you have is compatible.
- x 1045
The PSA part number is almost never stamped on the actual part itself. Its normally on a sticker on the box or bag the part comes in.
- x 6960
Exactly right.
Jucca
It's recognized by the Lexia:
Both pads, my original, and new one with power folding
With the new pad I can control right mirror, which is still original, so it's definitely working.
- x 6960
You may have partial function - because it depends on the nature of the signal type (Filament or Multiplexed). You will have an issue with functions associated with multiplexed operation if you don't have the corresponding kit.
Here's the issue - I can only compare part numbers used by PSA on their own systems - I can't provide the international number for comparison - if PSA don't have it listed for the part number. Sometimes they do and sometimes they don't.
Jucca
I have that option in Diagbox, checked multiplexed to yes.
So, whats the workaround? If there is one. Or return my new power fold mirrors, return the pad switch, and just to buy one regular mirror.
- x 6960
The answer is you need all the correct elements for it to work.
The correct Harness ?
The Setting in Diagbox ?
The Correct Mirror
The Correct Multiplexed Driver's Door Control Pad
The Correct Mirror
Jucca
Mirrors are good.
They're replacement parts of OEM codes:
OE-8153ZV
OE-8153ZG
OE-8153ZV
OE-8153ZG
