xantia no injection pulse
Post Reply
saeedm
My Cars: citroen xantia
x 16
Post by saeedm »
hi there.
the engine is xu10-rfv
car start for like 2 seconds and then turns of. after that it is not starting.
looks like it is not injecting fuel.
why it is not injecting fuel?
My Cars:
x 730
Re: xantia no injection pulse
Post by wheeler »
Have you confirmed there is no injector pulse with a noid light or similar? are the injectors being supplied with 12v? Are you getting a spark? can you see engine RPM in live data?
saeedm
x 16
Post by saeedm »
yes i checked with light and multimeter. it is not geting injection pulse.
all 4 injector connector have ground (-12volt).
when i sparyed fuel to air intake , it started!
so it have spark. and rpm is rising on dashboard when crancking.
saeedm
x 16
Post by saeedm »
update:
i disconnect all 4 injectors connector and checked them with light bulb. it was pulsing! but light was so weak!
then i ejected injectors and applied voltage to them from battary they are not injecting fuel still.
My Cars:
x 730
Post by wheeler »
Dont want to state the obvious but as you haven’t mentioned it is the fuel pump operating & is there fuel in the tank (don’t believe the fuel gauge)?
Is there enough fuel pressure?
saeedm
x 16
Post by saeedm »
last update:
i checked fuel injector and they was stuck and not operating
so i connect them directly to battery and tried to flush them.
and now car is working just like new.
My Cars:
x 730
Post by wheeler »
All 4 of them??
saeedm
x 16
Post by saeedm »
yes bro.
this car has not worked for 5 years!
injectors were stuck badly and they were clogged up
Post Reply
