Do you still put grease on your nuts?
JohnD
- x 72
Remember this subject that was put on the forum a few weeks ago. Around fifteen guys replied, and everybody used lubrication of one form or another. I put the same question on another of my forums - one which is for caravanners. About half of the thirty or so who replied did use grease, but the rest got really up-tight about NOT using anything. Even the Forum Admin. chipped in with a warning about posting misleading advice. To be fair - most caravans run on Alko chassis, and their information booklet states that "grease should not be used on wheel bolts". Personally, I still think Alko's advice is wrong. A lubricated thread which is correctly torqued, won't come loose.
wilkobob
fastandfurryous
- x 4
bxbodger
vanny
no copper slip for me!
Not for any particular reason, but i have a 2 and 4 foot breaker bar, and i also dont ever torque them up! Rattle gun them on and a quick half turn on the breaker bar and there pretty solid (solid enough to upset the tyre man!). When un doing them i get the breaker back on and they come off under my body weight!
i might also add that i carry an extendable wheel wrench in the car and this will also undo them when needed!
fastandfurryous
- x 4
I never used to use grease, but I had a 5 mile walk in the middle of the night because I broke one of those extending wheel-wrenches. when I got back to it over 2 hours later, I was still struggling with the 4' bar I was now using. When it finally went, it went with a big bang, and a small cloud of rust dust.
It was this experience that changed my mind!
ActivaV6uk
Kowalski
You have to be careful when you tighten things up with a greased thread because you can get things much tighter with the same amount of torque (about double), i.e. when you're given a figure for torquing a bolt the figure will either be specified for dry threads or oiled threads. The other thing you have to be careful of is that if you tighten something up with greased threads and get it tight, then the grease can disappear and you'll find it takes much more effort to shift it with dry threads.
bxbodger
The average torque wrench is going to be pretty inaccurate antway, so I don't think a thin sliver of grease is going to make much difference!! My torque wrench may have come with a calibration certificate but that was 25 years ago and I have no idea how accurate it is now-its probably close enough for jazz, anyway!!
Where grease is very useful is on chassis and suspension nuts that you know you are going to have to undo again at some time or other, and on BX brake bleed nipples, and, of course, the spare wheel cradle wind down bolt.It also makes the wheel nuts a lot easier to spin in and out.
Coppaslip is also essential when assembling alloy to iron parts, as anyone who has ever wrestled with a BL A series thermostat housing, or R series water pump will know.....grrrrr....grind....chop.....[xx(]
Its almost a pleasure to be able to strip a hub assembly off the car in 15 minutes, because you greased the nuts/bolts/pins etc last time, after it took 2 hours and at least one broken essential bolt...and we all know how much easier these things come apart when they've been subjected to years of oil leaks!!
I'm not advocating great big dollops of coppaslip, just a very tiny sliver is all it needs, plus a bit of water resistant grease on the exposed thread end.
oilyspanner
wilkobob
alan s
- RIP 2010
- x 6
Best I don't join the caravanners then; as I mentioned on the other thread, I have a 30 year old Evinrude outboard that has been used exclusively in salt water and I doubt that there's a bolt or nut that I have ever taken out that will not just screw straight out with no dramas if needed. Even the wheel nuts have a blob of waterproof grease on them and if I need to remove, I just ping it off, remove, refit and reblob.
I never remove anything that I don't either grease or oil on reassembly and I can't remember the last time that the same part was a problem to remove the next time I needed to access it.
Alan S
Alan S
fastandfurryous
- x 4
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Kowalski</i>
You have to be careful when you tighten things up with a greased thread because you can get things much tighter with the same amount of torque (about double), i.e. when you're given a figure for torquing a bolt the figure will either be specified for dry threads or oiled threads.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
The standard is for lubricated threads. It is standard engineering practice to lubricate a thread on re-assembly. The "special" case is dry threads, and that's fairly rare.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">The other thing you have to be careful of is that if you tighten something up with greased threads and get it tight, then the grease can disappear and you'll find it takes much more effort to shift it with dry threads.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
This is the whole point of copper grease. Even if the grease dries out (which would take several decades on a sealed component, and at least 5 years on an exposed-end thread) the "copper" part still remains, and since copper is a self-lubricating metal (easy slip planes in the crystal structure) then it will still be reasonably easy to dismantle.
To be honest, even bolts that I've lubricated with standard lithium grease have still come undone without drama decades later. I remember a small Briggs & Stratton lawnmower engine that I serviced when I was about 12. It was pulled apart again not that long ago, and suffered none of the usual steel-bolt-in-aluminium-casing problems, mainly because everything was greased on assembly.
alan s
- RIP 2010
- x 6
I have heard it suggested that "copperslip/copper grease" is a bit sus when used on or in anything alloy due to the potential of electrolysis particularly in a salty environment and that the aluminium grease/anti-sieze is a better option although the aluminium is a real "Whoops I got some on my hands, oh hell now it's on my spanners, oh shyte now it's on the phone, bloody hell I got it on my ear, how did it ever get on the door handle, who got it on the phone book, now it's on the flies of my new black suite, who got it on the handle of the tap, now the whole family's covered in it.................." kind of stuff![:(!][:(!] but has anybody else heard that about the copperslip??
Alan S
Alan S
andycarter
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I have heard it suggested that "copperslip/copper grease" is a bit sus when used on or in anything alloy due to the potential of electrolysis<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Probably the metalurgists out there will give a lengthy explanation why you shouldn't use it. In reality though, I reckon any electrolysis effect will be tiny compared to the water-borne corrosion resulting from not using grease.
Just my $0.02
Just my $0.02
