2004 c5 hdi 110 cooling fan woes FIXED and now running (pg 6 on) .
- x 6946
Re: 2004 c5 hdi 110 cooling fan woes and now not running....
No worries
citroenxm
- Fallen Hero
- x 70
Just to update.. I've picked up an ecu bsi and key for 45 delivered..
Arriving Sat or Mon...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 6946
Let us know how you get on....
citroenxm
- Fallen Hero
- x 70
I certainly will..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
OK.. Ecu and bsi fitted.. And vroom vroom off she went...
So now to interrogate the bsi install..
However.. VERY ANNOYINGLY.. the milage has changed. Its gone from 138k to 183k.. That's fairly irritating.
But it runs.
STOP PRESS... I've just. Done actuator test. On slow speed fan.. And it bloody works...
Well jeesus crist.. The redundant switch is working too...
But it runs.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 6946
There you go....
I didn't mention earlier Paul - as I thought you knew that changing an instrument panel or BSI will increase the mileage to whichever is the higher of the units when connected up - it's to help prevent mileage fraud.
But glad you have everything working.
citroenxm
- Fallen Hero
- x 70
I was aware of speedo clocks. But not bsi.. Anyway.. That's gonna affect my price now.
How do you switch off the auto lights. I know you press and hold the end of the stalk but that's all. They are on and I want them off..
Road test tomorrow now. Need to reattach front bumper. But fancy that both the slow fan AND cruise control rududant switch now working.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 3296
Re: 2004 c5 hdi 110 cooling fan woes FIXED and now running (pg 6 on) .
Great news, Paul (other than the mileage bit!). I wonder if you could send off both ECUs (mark them as 'original' and 'replacement') and the instrument panel, and get them all set to the mileage in the 'original' ECU? Then you should get the better price (and the last MoT would also help to prove the mileage).
- x 5674
That was a while back Paul - activating my CD autochanger
citroenxm
- Fallen Hero
- x 70
Brill thanks for that Steve.. Tomorrow's job. I. Being lazy really as I have got a mk 1 c5 handbook..
Incase anyone is interested in the first start and lexia readings..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
MGmike
- x 63
Great news and well done for persisting.
Hope it sells okay for you....
citroenxm
- Fallen Hero
- x 70
Oh crap just realised that's me not sitting in my car.. I look very different to that now..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 5674
It was a while ago.
Wetherby, Sun, 22 May 2011 12:48:19
citroenxm
- Fallen Hero
- x 70
An update..
Road test. Cruise still didn't work.. So put computer back on it was absent in engine ecu.. So put it on.. Hey presto. Cruise works.. Big Tick..
Slow running fan works.. Second big tick..
No egr fault as yet.. Will take it out a bit more and see how that goes..
Slight problem. Very annoyingly the rear drivers window keeps coming down in steps.. Like someone is pressing the switch.. It comes up on the drivers switch.. Then it will do down. Sometimes it doesn't.. Even if the power switch to the rear door switches is active so rear switches don't work.. It still goes down randomly.
So.. Bottom line. I was chasing something that wasn't an issue. And was an engine ecu problem all along.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1746
IIRC Paul, after battery disconnection (or presumably BSI monkeying), the driver's door one-touch window needs to relearn its travel. Done iirc by moving it down (or up?) in the small steps, after which it should have learned when to stop, and will operate smoothly. That's the XM system, anyway.
