Hi All,
My wifes C4GP Mk2 has the normal chrismass tree of fault. (ABS, ESP etc etc) I hooked it upto Diagbox and it showed rear right speed sensor. Great i thought, changed the sensor and the fault came back.
Thinking about it, it comes up more when it is wet. I guess i am going to have to trace the wiring. Does anyone know where the speed sensor connects into to? Where is the other end of the cable so i can check from point to point? Anyone have the pin numbers and control location.
Due to go to cornwall next week so will be putting 1,000+ miles on the car.
Any help would be great.
Wheel Speed Sensor Fault
- x 6946
Re: Wheel Speed Sensor Fault
My advice is to check the actual pins and connectors in the wiring block for the same sensor you replaced - we had a member recently with the same issue and it was a lose pin in the connector IIRC.
mikeyerfdog
Hi,
Thats what i plan to do but i dont know where the connector block is. Any ideas?
- x 6946
- x 6946
Here:
mikeyerfdog
Thanks, I checked that one. I want to check all the wiring right back to the controller. Where is that contrller so i can check that end's multiplug?
- x 6946
It will go back with the others to the ESP / ABS ECU which is at the rear of the engine bay near the left front wing (standing in front of the bonnet).
mikeyerfdog
Thanks,
I think you might me right tho. I have the 2pin plug a wiggle and it cleard last night. Will get the wheel off this weekend and confirm for sure.
Thanks for your input tho...
- x 6946
No worries - best of luck with it. Once you check the Pin, give it a clean with some Servisol or other electrical contact cleaner too.
