C3 airdream semi automatic Jolting
Naruto
- (Donor 2021)
Hi guys, really need some help, I have a c3 newly passed driver lol. Don't know much about cars. So I brought this c3 and it's developed a fault. It derived fine but after 35 minutes or over 30 miles in auto mode from the stopped position it revs but does not move forward, in the worse case, it rolled back as I was on a hill and then jolts forward like it's slamming into gear did the same in reverse. It keeps doing this until I park the car up for 5 minutes, then works again for ten minutes but then starts again with the same problem. If I wait 1 hour then it is okay for about 35 minutes again. Also, gearbox fault comes on the centre console a few times and transmission fault. I took it to the garage and the guy said that nothing wrong with lol, he said that Citroen has to be driven a certain way lol. Yesterday I nearly crashed because of this issue, so I was determined to get it sorted. Any help from you guys would be appreciated, My brother got his mate to put it on his standard computer and it did show gearbox fault code 2755 but when he checked the code, refer to the car manual which I tried to find with no luck. the car a C3 airdreaam vtr+e+hdi s-a 2012
Naruto
- (Donor 2021)
Re: C3 airdream semi automatic Jolting
sorry forgot to mention it's semi-automatic with the flappy paddles 1.4 diseal Citroen C3 Airdream vtr+E-HDI S-A. Is there anyone who you can recommend or suggest before I take it to a garage for repair? Thankyou
- x 3306
Hi, and
to the Forum. I personally cannot offer you any direct help, other than to suggest you post the vehicle VIN here (in this thread). It will allow the Forum Staff to look up you vehicle and get more accurate information. Don't worry, the VIN will automatically be obscured so only Forum staff can read it (like this, for example; VF7**************[VIN obfuscated, can be read by forum staff] ).
Naruto
- (Donor 2021)
vin is VF7**************[VIN obfuscated, can be read by forum staff] Hope that helps and thankyou for the kind welcome
- x 6956
Unfortunately that is not a recognised fault code - so can't help with that one. Was it a recent purchase and if so, was it from a garage? If so, what are the chances of you taking it back as this is likely to be costly to fix - not least as it first needs a good diagnostic with Diagbox so find out what it's unhappy about. The trouble with these piloted systems is that they are not true automatics - they are essentially a manual gearbox and clutch like any manual car, but have electro-hydraulic actuators to do the gear and clutch changes controlled by electronics. This is why it can be expensive finding out what the issue is.
Naruto
- (Donor 2021)
Hi Mate thankyou for the reply it was a private buy and over a month ago no chance of a refund. I don't mind paying for it to repair it. I just want make sure I get repaired correctly and not do stuff that is unnecessary. It is probably an actuator, solenoid or clutch. My brother mate who owns a garage say it actuator but rather get advice from you guys first.
Reason: Removed Quote (Unnecessary for Previous Post)
- x 3306
What you might want to do first is to get her properly diagnosed with a diagnostics system that 'understands' Citroens and Peugeots. There are Forum members who have such equipment, and some of them are prepared to help other forum members. There is a link to these members (but please be aware that some of them have 'gone quiet' and my not respond to PMs;
viewtopic.php?t=56452
Naruto
- (Donor 2021)
Thanks mate do any of these guys do repair service as well, I know some mechanics are now mobile and can quote a price before I book one wanted to know what cost I am looking at to fix this car as I need it for work. The job I do requires me to use my car so I need it to be safe to drive. I live close to Bradford nearest guy to do reading is Wakefield, I don't think I am confident enough to drive it there lol.
- x 6956
I would advise against driving it like this as it may have the potential to make it worse or do more damage. There are over a hundred fault codes for this system, so unless you know what the exact issue is you will be heading for big bills - the time taken to investigate these can be extensive, so I would suggest you get it to a dealer - reason being they will have extensive experience with these systems and it may save you faffing about with other garages that are not as experienced as well as be cheaper to fix if they can determine the problem for you straight away with an estimate.
If you are prepared to pay for it to be repaired, then get it diagnosed at the dealer and if you get it repaired with them, they should provide you with a free courtesy car whilst it is being fixed so you can get to work.
Naruto
- (Donor 2021)
Hi I took it to another garage better computer. I attached the report to the post two faults, one minor fault oil gauge other gives unknown fault: P175525 - A6200101GiveMeABreak wrote: 16 Jul 2021, 11:05 I would advise against driving it like this as it may have the potential to make it worse or do more damage. There are over a hundred fault codes for this system, so unless you know what the exact issue is you will be heading for big bills - the time taken to investigate these can be extensive, so I would suggest you get it to a dealer - reason being they will have extensive experience with these systems and it may save you faffing about with other garages that are not as experienced as well as be cheaper to fix if they can determine the problem for you straight away with an estimate.
EOBD Fault: P1755
Does anyone know what these codes mean.
- x 6956
This is isn't going to help as you can see - the possible causes are far ranging, hence my dealer suggestion ......
It may need recalibrating to set the clutch biting point - but that's just a guess at this stage.
| Fault Code: | P1755 |
| Description of Fault: | Clutch actuator fault: Coherence. Difference between the reference position and the measured position. Difference between the reference position and the measured position. The time of appearance of the fault code is 1s. Warning lamp / Warning lamp MIL will be lit. |
| Conditions for Fault to clear: | Difference between the reference position and the measured position below the threshold. |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
