I’m trying to activate the AUX input on my radio with Lexia.
Problem is that as soon as I go in to the radio to configure it, I just get a blank line. Any clues why?
Activation of AUX on C5 radio
Moderator: GiveMeABreak
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5648
Re: Activation of AUX on C5 radio
When you ran the global test, was there an ECU for the RD4 or just Autoradio? Which system do you have fitted?
Is Lexia picking up all the other detected ECUs?
The radio says Blaupunkt RD4 on a label, but lexia only said Radio when running global test. In total it found 10 ECUs if I’m not mistaken…
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, so without getting the main menu up for the ECU,. you are not going to get into the configuration screen. Maybe your VCI is a revision B and not fully CAN compliant with missing hardware. The cheaper Chinese clones did cut-down versions that have issues with the C5. If the VCI can't communicate with the some ECUs that may be where your problem lies. Are you using Diagbox which launches Lexia automatically, or a native Lexia only installation? If Diagbox, what version of software are you on?
