Cracking C5 spheres needed befoire removal?
aneesh84
x 29
Unread post by aneesh84 »
Whenever I used to remove Xantia spheres, I used to first crack the sphere by putting the Car on high position, and hammering it a quarter of a turn before depressurising and removal.
Is the same needed for C5? In the instructions posted for C5, I did not find any reference to such a procedure prior to depressurisation.
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
x 6954
Re: Cracking C5 spheres needed befoire removal?
Not normally, as these should only be hand tight, but they can become stuck with age - so you may need to gently coax it.
MGmike
x 63
Unread post by MGmike »
Chisel and a big hammer will be needed if you don't have a a removal tool.
https://www.ebay.co.uk/itm/114879624619 ... SwLe5avT8r
aneesh84
x 29
Since they are factory fitted, I am expecting some resistance. Thank you for the confirmation!
C5 2005 2.0 HDI 138
aneesh84
x 29
MGmike wrote: 11 Jul 2021, 17:43 Chisel and a big hammer will be needed if you don't have a a removal tool.
I was going to order that tool. But with Brexit, importing things into Europe from UK is a pain. You pay huge charges and taxes and takes over a month to receive the item, probably stuck at customs. I couldnt find any EU supplier.
I will try with this tool from Norauto.
https://www.norauto.pt/p/chave-de-esfer ... galContent
C5 2005 2.0 HDI 138
x 3297
You could always try making your own sphere removal tool;
https://www.frenchcarforum.co.uk/forum/ ... hp?t=21850
x 1056
Unread post by wheeler »
aneesh84 wrote: 11 Jul 2021, 15:52
Yes, always loosen on high, for the rears anyway. If you don’t its likely the whole strut will spin as you try to undo them.
x 1751
Home-made jobbie. Anyone with welding kit could make up one of these for you...
Form the loop around an old sphere when making it.
