Citroen c5 x7 2.0hdi rpm issue
Gregor
x 16
Re: Citroen c5 x7 2.0hdi rpm issue
Unread post by Gregor »
I have similar issues and today I'm going to swap crankshaft speed sensor... Hope it will cure jerkynes and I'll keep you posted.
Driving Citroen is a diagnose!
vasilus_rs
Unread post by vasilus_rs »
It's not the sensor, it's "CRANKSHAFT PICKUP SENSOR RING 0515T7" the one under the crankshaft pulley you will have to remove the pulley to get to it. And because I wanted to fix it last weekend but euro car parts and gsf car parts doesn't have it I started looking for the second hand one but every single one was sold. So I bet they go bad very often.
https://PrivateLadyEscorts.com - Dating Chat With Private Lady - No Verify - Anonymous Adult Dating - Secret Live Local Private Lady
x 6958
They will if you get it from ECP! They do have a poor reputation here amongst myself and other members for dead parts, parts broken, not working that have caused wasted time on tracking non-existent faults when it was faulty parts.
vasilus_rs
I bought it new from eBay 17£ it was with me on the second day after the order and it's working fine.ECP doesn't sell them
Gregor
x 16
Was your ring mechanically damaged? It should just be a ferromagnetic passive ring, can't understand what could fail if not damaged (broken tooth...)?
Gregor
x 16
AutoDoc holds them on stock for aprox. 15 EUR or less (Febi, Swag, INA, Corteco)
vasilus_rs
Gregor wrote: 24 Jun 2021, 12:07 Was your ring mechanically damaged? It should just be a ferromagnetic passive ring, can't understand what could fail if not damaged (broken tooth...)?
no, it wasn't visually. I'm not familiar with those it's my first one ever done.
Gregor
x 16
after replacing rpm sensor, i have got peace from errors. Car stoped hard cutouts but still jerky running when cruisecontroll is in use and driving down the hill. anoying for me. now also black smoke is back.... grrrrr.
BR Gregor
moizeau
x 428
Unread post by moizeau »
Gregor wrote: 06 Jul 2021, 16:34 after replacing rpm sensor, i have got peace from errors. Car stoped hard cutouts but still jerky running when cruisecontroll is in use and driving down the hill. anoying for me. now also black smoke is back.... grrrrr.
BR Gregor
My 407 has done this since I had it. I put it down the auto box. Then it's started doing it on very light revs. I've unplugged the MAF (which throws the light on after a couple of starts but no limp mode) it's not done it since. Just need to give the MAF a clean now.
Pete
Gregor
x 16
did that allready, but no fun...
