C5 X7 Windows Motor
KeithG
C5 X7 Windows Motor
The electric motor on my 2010 C5 Tourer driver side window has failed ,just getting a clicking noise . Are these fixable or will I need a new motor ?
Steve Walsh
- x 515
Re: C5 X7 Windows Motor
The clicking could be due to the mechanism failing, and jamming, It would be worth taking inner door card off and having a look
KeithG
Thank you -will check that.
- x 6955
Please don't mix separate issues on the same thread.
I've split this topic into a new one and moved it out of the MyWay Telematics to the Citroen Technical Forum.
Your motor may be fine, but the regulator wiring may have snapped or jammed up. Water gets in and they rust and ultimately snap.
- x 3566
I did a 'How to' fix the winder mechanism in the member's area:
viewtopic.php?t=57993
