Please help with the electronic handbrake
depo1902
Unread post by depo1902 »
Hello dear owners of French cars!
When trying to free the rear calipers using diagbox 9.68 to replace the rear pads, several bugs popped up, including the C156D62 which does not wear off and the handbrake is no longer tightened.
In this case, the handbrake signs are constantly flashing on the dashboard.
Today I checked the wiring, it is intact without damage.
My car is a 2018 Citroen c4 Grand picasso, 1.6 bluehdi engine with aisin automatic transmission.
Unfortunately, I do not know English and I use google translator, thanks for your understanding.
x 1056
Re: Please help with the electronic handbrake
Unread post by wheeler »
Might be worth trying to recalibrate the system with diagbox & go through the procedure as if you have replaced the calipers/cables.
escortcvh
New User
Unread post by escortcvh »
Good night, my friend. I have a great friend who has changed the rear pads of a Citroen C4 Grand Picasso 2018. And you have the same fault as you, the C157D. Could you tell me if I solve it, and how did you get it? A cordial greeting from Spain.
Craigalanarm
Unread post by Craigalanarm »
How do all. I have the same fault C156D62 on a 2018 C4 B78 2018 model 1.6 HDI 120BHP. Tried to recalibrate as if new caliper as above but the calibration cannot be completed due to the active code. The DTC will not clear after the partial calibration. Any help would be greatly received. Using the Topdon topscan tool.
Craigalanarm
Update to my specific issue. I managed to clear the fault by having the engine running and holding the handbrake switch on for more than 10s with my foot on the brake (normal handbrake application procedure) which then activated the actuators to work normally and then allow me to clear the ABS DTC.
Plnm
Unread post by Plnm »
Buenas tardes porfa una consulta cambie las pastillas de freno traseras y ahora me da fallo de freno de mano eléctrico, este no me funciona, pero siempre funcionó perfecto.
Intenté destensar previamente al cambio de pastillas los estribos con diagbox pero no me funciono, pero pude cambiar las pastillas sin problema.
El fallo que me da en diagbox es el C156D62
Alguien me puede ayudar por favor.
x 5674
Please write in English. If you are unable then please use a translator, i.e. Google Translate or DeepL.
Your original text translated by DeepL is below.
Por favor, escriba en inglés. Si no puede, utilice un traductor, como Google Translate o DeepL.
A continuación encontrará el texto original traducido por DeepL.
Good afternoon, please ask me a question, I changed the rear brake pads and now I have an electric handbrake failure, it doesn't work, but it always worked perfectly.
I tried to untension the calipers with diagbox before changing the brake pads but it didn't work, but I could change the brake pads without any problem.
The fault I get in diagbox is C156D62.
Can someone please help me.
x 6946
C156D 62: Electric parking brake (EPB) actuator sensors: Lack of coherence of the signal
Fault Code: C156D 62
Description of Fault:
  • Electric parking brake (FSE) actuator sensors: Lack of coherence of the signal.
    Description of the diagnostics
    Possibility 1
  • The ESP ECU is checking the final status of the motorised brake calipers
    Possibility 2
  • The ESP ECU is checking the final status of the motorised brake calipers in relation to the demands being made on the actuator motors.
  • The fault immediately appears
Conditions for Fault to clear:
  • Operating status of the motorised brake calipers
Downgrade Modes whilst Fault is active:
  • Checking of the motorised brake calipers: Only loose.
  • Electric parking brake: Dynamic application only.
  • Deactivation of the "Stop and Start" function.
  • Switching on of the warning lamp and/or warning message: "SERVICE" warning lamp and message "FSE faulty".
  • Warning lamp "Auto P Off" and orange warning lamp "(P)!".
Symptoms:
  • Parking brake faults
Suspect Areas:
  • Electrical harnesses
  • Connectors
  • Fuses
  • Service battery
  • ABS/ESP ECU
I suggest you start the vehicle and manually activate the switch to apply the parking brake and hold it applied there for at least 10 seconds to ensure that the EPB applies maximum application of the parking brake.
If this fails then try a BSI Reset / Battery Disconnect / Reconnect Procedure
Plnm
Muchas gracias por su respuesta
Volvía a probar nuevamente las dos opciones que me dice y no consigo que funcione.
No sé que será.
x 6946
Then you'll probably need to get it to a specialist for further examination as to the actual problem. If it was working fine before you undertook the work, then it's likely to be something that has happened as a result of the work.
Esparbero
Unread post by Esparbero »
Plnm wrote: 12 Sep 2024, 12:08 Muchas gracias por su respuesta
No sé que será.
Hola
¿Has podido reparar tu freno? Estoy en las mismas circunstancias que tú. Te agradecería me indicaras la solución.
Gracias
Hello
Could you repair your brake? I am in a similar situation. I would be very grateful you show me the solution.
