Xantia 99 Pollen Filter Removal
jmd
Unread post by jmd »
For the benefit of anybody contemplating the above job. According to the Haynes Manual. Removal of the above is carried out by "2 Remove the 3 securing screws and withdraw the lid from the Pollen Filter Housing". I spend a considerable length of time searching for the 3 screws concerned, to discover that these screws do not exist in my car, which has a lid that slides off towards the centre of the car. Just thought I'd pass this on & save others time & frustration. ( Perhaps this "Pollen Filter Lid Removal", differs from car to car)
Ross_K
x 110
Unread post by Ross_K »
Yep, I did mine today as well and was wondering where the hell the screws were... :D
Looks like the filter in mine was in there since the car was made. Clogged isn't the word.
On the plus side I fiinally got around to stashing the "brain" for my phone kit under there too :D
x 1425
Unread post by xantia_v6 »
For anyone contemplating changing their pollen filter, if you suffer from pollen allergy/hayfever, stay away from GSF or even Citroen filters, and get one of the better aftermarket filters (e.g http://www.puravent.co.uk ).
The cost a bit more (~£20) but they keep my allergy to pollen under control, while the GSF/Citroen filters do not.
2.1td
Re: Xantia 99 Pollen Filter Removal
Unread post by 2.1td »
jmd wrote:Remove the 3 securing screws and withdraw the lid from the Pollen Filter Housing". I spend a considerable length of time searching for the 3 screws concerned, to discover that these screws do not exist in my car, which has a lid that slides off towards the centre of the car. Just thought I'd pass this on & save others time & frustration. ( Perhaps this "Pollen Filter Lid Removal", differs from car to car)
Think this refers to the screws which hold the fibre trim that covers the filter box housing!
2.1td
Be careful!
x 1425
2.1td wrote:
jmd wrote:Remove the 3 securing screws ...)
Think this refers to the screws which hold the fibre trim that covers the filter box housing!2.1td
No the early cars had screws holding the pollen filter cover, which then pulled straight down. So Haynes is correct for those.
MikeT
x 232
Unread post by MikeT »
jmd wrote:For the benefit of anybody contemplating the above job. According to the Haynes Manual. Removal of the above is carried out by "2 Remove the 3 securing screws and withdraw the lid from the Pollen Filter Housing". I spend a considerable length of time searching for the 3 screws concerned, to discover that these screws do not exist in my car, which has a lid that slides off towards the centre of the car. Just thought I'd pass this on & save others time & frustration. ( Perhaps this "Pollen Filter Lid Removal", differs from car to car)
Snap! Took me ages to realise there were no screws on mine, just slide bottom cover towards centre console. I wondered why I wasn't getting the screen demisted....
Stewart(oily)
x 35
Unread post by Stewart(oily) »
Mine looked like that too, a hundred thousand miles of bugs, it demists better now.
Stewart
jmd
Mine was not that bad, the car is year 99, purchased recently. The Filter had an 05 date, so evidently it had been renewed. I washed it & left it out to dry, on one of the Sunny days last week. The LHM fluit looked terrible, and I am now running on Hydroflush. So much for "Full Service" history. I often discarded better looking LHM on my old car after 30,000 miles.
Stempy
Unread post by Stempy »
jmd wrote:Mine was not that bad, the car is year 99, purchased recently. The Filter had an 05 date, so evidently it had been renewed. I washed it & left it out to dry, on one of the Sunny days last week. The LHM fluit looked terrible, and I am now running on Hydroflush. So much for "Full Service" history. I often discarded better looking LHM on my old car after 30,000 miles.
Funny thing about LHM, when I had my old 2 litre Xant I took it to a Cit dealer for a service and asked them to change the LHM. When I got the bill they had only charged for 1 litre which I thought was a bit strange, but at the time I was much less Xantia savvy so I didn't persue it. I can only assume that all they did was suck out what was in the reservoir tank and replaced that only :roll:
Lexia ponce
TehAgent
x 6
Unread post by TehAgent »
er... where exactly is the pollen filter? as my car has a hard time demisting, and after reading this, I'm going to put it down to the pollen filter.
Peugeot 208 active 1.6 EHDi
BMW 330i 2007
Mx5 Mk1 1990
Xaccers
x 186
Unread post by Xaccers »
TehAgent wrote:er... where exactly is the pollen filter? as my car has a hard time demisting, and after reading this, I'm going to put it down to the pollen filter.
Pull down (after removing the screws) the carpet under the glove box.
There's a long thin panel to the right of the motor.
Slide this aside (I can't remember which direction, but mine was very tough) and then pull out the old black feather covered filter.
Make a note which way the slanted top goes.
Either wash or replace.
DIY sphere tool
TehAgent
x 6
ill give that a go in a min, when you have replied to my pm Andy :)
BMW 330i 2007
Mx5 Mk1 1990
Xaccers
x 186
TehAgent wrote:ill give that a go in a min, when you have replied to my pm Andy :)
Replied :)
DIY sphere tool
jmd
Slide towards the centre of the car- away from the passenger door. Although the earlier models pre 99 may have 3 screws
aneesh84
x 29
Re:
Unread post by aneesh84 »
jmd wrote: 19 Jun 2007, 02:07 Slide towards the centre of the car- away from the passenger door. Although the earlier models pre 99 may have 3 screws
It is so tight, doesnt move with hand. Can i use a hammer?
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
