Confusion reigns...Which engine??
BigBadJonno
Unread post by BigBadJonno »
Hi,
I'm off to look at a C3 Picasso this afternoon to replace the wife's ageing Meriva.
It's a 2010 Airdream+ and HPi is showing it as a 90bhp, but I'm absolutely confused by the number of possible engine codes for this car. Is anybody able to tell me which engine is fitted and whether it is 16v or 8v and whether it has Eolys or FAP/DPF fitted please?
Reg No. is PK60 APX
I'm assuming it's due a timing belt at 10 years (so potentially overdue then....). Seller claims 'Service History' but we'll have to wait and see what that means...
Many Thanks
Jonno
x 6955
Re: Confusion reigns...Which engine??
Hi
It's an HDi not an HPi. The HPi was the designation for the High Pressure Petrol Injection engines.
So there are several 1.6 HDi models and these are 8V engines. These should all be fitted with a Diesel Particle Filter. If the timing belt hasn't been done, then yes allow £500 for this (Citroen fixed proce repairs are offering this fully fitted price at some dealers).
If you havce the VIN at some point I can tell you exactly which engine you have and confirm DPF or not.
BigBadJonno
Thanks Marc,
HPi reference is to the car checking service. It lists the car as a 90bhp version.
I'll post further once i have the VIN, providing it's not a complete lemon.
Cheers
Jonno
x 1056
Unread post by wheeler »
Here you go.
C3 PICASSO FAMILY SALOON 1.6 HDi 92 (DV6DTED) Manual gearbox 5
ENGINE TURBO DIESEL DV6DTED
FUEL SUPPLY DIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) EURO 5 L6 UPPER ENGINE EMISSION CONTROL
ENGINE (TYPE) DV TYPE ENGINE
CATALYTIC CONVERTER CATALYTIC CONVERTER LESS THAN 10PPM
FUEL TANK FUEL TANK WITHOUT LOCATING TAB
COOLING MOTOR RADIATOR TH : 18 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION TECHNICAL VEHICLE EMISSION CONTROL EURO 5
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
FAN 1 AERO 2-SPEED 140W FAN WITH SCOOP
TANK FILTER CITHOUT RESERVOIR FILTER
STOP AND START WITHOUT STOP AND START
BigBadJonno
Thanks Wheeler, that's great!
