C5 x7 Tourer suspension part number help
Clarkie89
Unread post by Clarkie89 »
Hi,
Had a spring snap on my c5 tourer. It's getting on now (2009, 135k) so figured I'd replace the whole strut assembly to save having to do it again any time soon and to make my life a bit easier (bad experience with a top mount previously on a different car)
Been having a look round for parts and there seems to be a few different OEM part numbers coming up when I put in my reg. I was wondering if anyone here knew how to figure out which one I'm after?
x 1484
Re: C5 x7 Tourer suspension part number help
Post up your VIN and we can check
x 6955
Clarkie89 wrote: 19 May 2021, 04:37 Hi,
I have your VIN - but you didn't mention front or rear? and secondly is it both springs and shock absorbers you want?
Clarkie89
Sorry was half asleep when I wrote the post. It's for the front and I was thinking of doing the shocks and the springs at the same time as it saves me taking it apart again any time soon.
Another question if you don't mind, I was looking at the top mount for the struts and a lot of them are saying without roller bearing? A few say with so I'm assuming it needs the bearings?
Thanks for the responses guys.
x 6955
Springs of course, must be replaced in pairs.
There are several options that could of been fitted to your vehicle, and were generally colour marked, but I think these are the standard ones:
Front Springs
Part: 9801945480 (Orange, White & Blue marking) £135.96 each
Struts
OEM Original Front Shock Absorber part: 1628564280 which must also have the bumper spacer below! £102.53 Each.
Bumper Spacer (required) 9800965480, 0.69p each.
Or there are Cheaper ones supplied by Citroen, part: 1635532480 at: £111.22 each.
The mounting bracket (3) is: 9800479780, £56.80 each
All prices inc. VAT correct at time of posting from Citroen.
Any other part you think you'll need from the above, shout.
