XM LHM Filter Clip Part Number
OnlineHell Razor5543
- x 3302
Re: XM LHM Filter Clip Part Number
That is assuming it is still in the tank.
wesacosa
- (Donor 2021)
- x 3
yeah who knows. I only just got the car so whoever last did the filters could easily have lost it. Its didn't come out with a shake or the tank so not hopeful but will give it a good going over in case its stuck somewhere
wesacosa
- (Donor 2021)
- x 3
A lot of the read ups on changing the LHM I have read on here talk about removing a white plastic disc from the LHM tank which all the gunk collects underneath, but I don't see any such disc. All I can see is the internal baffles. Is the XM tank different or am I missing something?
The only white disc I found was the one that seems to have fallen off the bottom of the level indicator tube
wesacosa
- (Donor 2021)
- x 3
Hi
Was wondering if anyone had the part number for the hose clips for the main pump supply hose from the LHM tank for 97 XM, or if anyone has a suggestion for a suitable after market one if Citroen no longer stock them
- x 1751
These clips are genuinely circular, and good on small hoses which mustn't leak - especially that (suction) hydraulic line.
They're stainless, neat and have a small tang which is lifted to vertical to release the clip - no need to cut it.
https://www.amazon.co.uk/Proster-Single ... 479&sr=8-1
There are some kits of these that come without the pincers, if you aleady have a pair - but check they have the release tang; some don't.
wesacosa
- (Donor 2021)
- x 3
thanks, they look pretty handy to have around the garage. Ordered a set
