Peugeot 407 2.0 hdi "bucking" and ESP/ASR fault
Post Reply
barrymurphy
My Cars: Peugeot 407 2.0 HDi 2009
Post by barrymurphy »
Hi,
My car will start fine and run for a while but then might "buck"/jerk, keep on driving, then might do it a while later, then on occasion after doing it
the ESP/ASR fault appears. If I turn the car off then back on the fault goes away.
There is no consistency in the time frames between jerks. Might be twenty minutes or could be a few. But it would be at least one or two in an hour.
There is no EML on.
Does anyone know what this is? Stuffed EGR valve?
Regards
Barry
barrymurphy
Re: Peugeot 407 2.0 hdi "bucking" and ESP/ASR fault
Or a faulty crank sensor? but that would turn the EML on?
Abdul
My Cars: 406 206 307 407 408 4008 1007 206cc 106 508 5008 3008 207 citroen car etc
Post by Abdul »
Check the egr valve
barrymurphy
I will definitely be doing that but what has me questioning it, is the jerks are quite sharp, there is only ever one jerk and its sharp and sudden and the car then keeps going. It could be too sharp a jerk for a clogged EGR?
Does the clogged EGR not produce more regular "coughing" like symptoms?
Post Reply
