Citroen C4 Grand picasso 2008 BSI exchange
krycha3223
Hello , I've changed BSI ,because old one has died. No communication at all with all modules. When i put new(used) BSI virgin I've done configuration with Autel ,but clusters whole time are black no lights. What could be wrong ? Thank's for advice.
- x 6955
Re: Citroen C4 Grand picasso 2008 BSI exchange
But has the new unit been programmed with the customer confidential code that the engine ECU and transponder keys use? These as you are probably aware are a matched set. So configuration of the options are not enough - it must be coded to the vehicle.
If you've done all that, then something isn't right or the BSI is the wrong type. Hard to say.
